What brake pads to use with Spoon calipers?
Old Apr 17, 2004 | 03:22 PM
1337 Si's Avatar
Default What brake pads to use with Spoon calipers
I just bought a set of Spoon brake calipers for my Civic with a 5 lug conversion, and I am wondering what brake pads I can use with them? Also, will I need shims for them? Anyone of you that has them, please give me your insight, thanks.
Old Apr 18, 2004 | 12:02 AM
98itR484's Avatar
Default Re: What brake pads to use with Spoon calipers (Boosted Ego)
any brake pads that fit the ITR caliper fit the spoon caliper, the spoon caliper is considered a OEM replacement.
You can either buy OEM Honda brake pads for a ITR, or better yet call up Andy @ Cobalt and pick up a set of his pads for a ITR.
I personally run the Cobalt VR spec pads, on the track and on the street
Yea it dusts alot, its a metallic pad, however i really dont drive the car on the street anymore so i can live with it
Old Apr 18, 2004 | 08:12 AM
2000 Integra R #760's Avatar
Default Re: What brake pads to use with Spoon calipers (98itR484)
I ran endless NA-M and they worked great. They are very low dusting but have great initial bite and low fade. You do not have to use shims with 4 pot calipers
Old Apr 18, 2004 | 10:00 AM
1337 Si's Avatar
Just outta curiosity why is your bleeder on the top and hot on the bottom? I haven't installed mine and that just seems strange. Thanks for the help guys. Know anywhere I can get those project Omega pads?
Old Apr 18, 2004 | 10:11 AM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Ego &raquo;</TD></TR><TR><TD CLASS="quote">Just outta curiosity why is your bleeder on the top and not on the bottom? </TD></TR></TABLE>
Because you want to "bleed" air and not fluid, otherwise (if the bleed screw was at/on the bottom) you would never get an air bubble out of the caliper.
Old Apr 18, 2004 | 11:12 AM
uNF$@#!'s Avatar
Default Re: What brake pads to use with Spoon calipers (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">
Because you want to "bleed" air and not fluid, otherwise (if the bleed screw was at/on the bottom) you would never get an air bubble out of the caliper. </TD></TR></TABLE>
yes you could, just suction your mouth on the brake reservior and blow real hard....
Old Apr 18, 2004 | 11:24 AM
JDM Factor's Avatar
Just remember to shave the tabs off the back of the brake pads for the caliper.
Old Apr 18, 2004 | 11:27 AM
JDM Factor's Avatar
Sorry, I'm not trying to steal the post, but does anyone have brake fade problems since they switched from the O.E caliper to the Spoon Caliper? I tried a lot of different brake pads, and the only one's I found that worked best were the Cobalt GT Sports. Also, does anyone have any problems with ABS locking up to quick? Right now the setup is Michelin Sport cups, GT Sport pads and Brembo blanks.
Old Apr 19, 2004 | 08:12 AM
1337 Si's Avatar
Default Re: (JDM Factor)
Oh, you mean those two little nipple things on the back of the pad?
Old Apr 19, 2004 | 08:19 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
Default Re: (Boosted Ego)
You have to remove the squeal indicators (the metal clips) that come with the stock pads. *Most* aftermarket pads don't come with squeal indicator so you're ok. But some still do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Factor &raquo;</TD></TR><TR><TD CLASS="quote">Sorry, I'm not trying to steal the post, but does anyone have brake fade problems since they switched from the O.E caliper to the Spoon Caliper? I tried a lot of different brake pads, and the only one's I found that worked best were the Cobalt GT Sports. Also, does anyone have any problems with ABS locking up to quick? Right now the setup is Michelin Sport cups, GT Sport pads and Brembo blanks.</TD></TR></TABLE>
I haven't experienced any fade or warped rotors with the Spoon calipers. And it actually locks up less because you can modulate the brake better than the stock single-piston.
Old Apr 19, 2004 | 08:21 AM
Kicker773's Avatar
Default Re: (Wai)
interesting.. will be in the market for one soon
Old Apr 19, 2004 | 09:08 AM
1337 Si's Avatar
Default Re: (Kicker773)
Can't wait to actually get these on my car!!
Old Apr 19, 2004 | 11:29 AM
JDM Factor's Avatar
Yeah BoostedEgo, just remember to sand those tabs off the cobalts, if you don't ur gonna screw the pad, rotor, and caliper up.
Old Apr 19, 2004 | 11:30 AM
JDM Factor's Avatar
Installing the calipers, do the washers Spoon gives you, go between the caliper and the mounting bracket or on the bolt?
Old Apr 19, 2004 | 12:05 PM
RagingAngel's Avatar
unless I fooked up my install totally.
It goes 1) BOLT 2) washer
I've been rolling on them trouble free for almost 2 years even in the wet miserable winters of the PacWest.
Old Apr 19, 2004 | 01:28 PM
esponet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Factor &raquo;</TD></TR><TR><TD CLASS="quote">Installing the calipers, do the washers Spoon gives you, go between the caliper and the mounting bracket or on the bolt?</TD></TR></TABLE>
look on the isntruction sheet. depending on what you have the bolt either goes bteween the caliper and knuckle used as a spacer)or between the caliper and bolt. (used as a washer)
Old Apr 19, 2004 | 02:13 PM
1337 Si's Avatar
Default Re: (esponet)
Wait, I just got a caliper........is there something else I need for proper install?
Old Apr 19, 2004 | 02:20 PM
JDM Factor's Avatar
Just ready the instructions! It's not that big of a deal. The washer is on the bolts not between the knuckle and the caliper on my setup, and has been fine.
Old Apr 19, 2004 | 02:49 PM
cougar10ag's Avatar
funny. i read the bleeder screw is supossed to be on the bottom... but that was a different company.
Mugen112
Honda S2000
10
Jun 2, 2008 12:12 PM
Quickridez_3
Apr 4, 2008 04:29 PM
sato1
Jul 23, 2007 12:03 PM
itrsport.com
Jul 21, 2002 02:00 PM
ITRaholic
Jun 23, 2002 01:58 PM
