CTR TB vs. ITR TB
Old Apr 17, 2004 | 02:34 PM
ej1times's Avatar
Default CTR TB vs. ITR TB
Ok, I just wanted to know if there is a difference between the ITR throttle body and the CTR throttle body. If this topic has already been discussed I'm sorry for reposting and would appreciate a link to the thread that discusses this topic. I did a search and came up with no results, Thanks.
Old Apr 17, 2004 | 03:42 PM
GSR-Civic's Avatar
There the same
Old Apr 17, 2004 | 03:49 PM
VtecDeMoN's Avatar
Default Re: CTR TB vs. ITR TB (ej1times)
If I'm not mistaken, the CTR is the same as all b16 throttle bodies and the itr is 2mm larger.
Brian
Old Apr 17, 2004 | 05:22 PM
ej1times's Avatar
Default Re: CTR TB vs. ITR TB (VtecDeMoN)
that is what I thought but if anyone else has any information on this topic please post. Thanks
Old Apr 17, 2004 | 06:31 PM
Ricey McRicerton's Avatar
I KNOW the ITR TB is a 62mm peice. I don't know what size the CTR is though.
Old Apr 17, 2004 | 06:39 PM
FlatBrokeHatch's Avatar
Default Re: CTR TB vs. ITR TB (Ricey McRicerton)
bump
Anyone know for sure?
Old Apr 17, 2004 | 06:43 PM
Nikos's Avatar
Default Re: CTR TB vs. ITR TB (FlatBrokeHatch)
From now on you guys need to be more specific...
The JDM k20a Civic Type-r has the same TB as the JDM ITR K20a. It is 62mm.
I know you are most likely asking about the b18b TB... Not sure about that
Old Apr 17, 2004 | 06:56 PM
Default Re: CTR TB vs. ITR TB (Nikos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikos &raquo;</TD></TR><TR><TD CLASS="quote">From now on you guys need to be more specific...
I know you are most likely asking about the b18b TB... Not sure about that </TD></TR></TABLE>
B16B bud. Be more correct with your info.
Old Apr 17, 2004 | 07:14 PM
pdiggitydogg's Avatar
I was pretty sure theyre the same size @ 62mm
Old Apr 17, 2004 | 07:34 PM
92RED Hatch's Avatar
Default Re: (pdiggitydogg)
all B16 aren't the same. USDM B16's have a 58mm tb...the JDM B16 has a 60mm tb. Yes the ctr and itr B series both have a 62mm tb
Old Apr 17, 2004 | 07:49 PM
Nikos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
B16B bud. Be more correct with your info. </TD></TR></TABLE>
Damn it!!! I told them they should make you a moderator!!
Old Apr 17, 2004 | 07:51 PM
Damn it!!! I told them they should make you a moderator!! </TD></TR></TABLE>
I wouldn't do it for the world. Too many fucktards on here to even begin. But you were correct, he does need to be more specific.
Old Apr 17, 2004 | 07:53 PM
JeffS's Avatar
I just measured an actual CTR throttlebody and it is 62mm.
Modified by JeffS at 1:02 AM 4/18/2004
Old Apr 17, 2004 | 08:43 PM
Hybrid96EK's Avatar
Default Re: CTR TB vs. ITR TB (JeffS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffS &raquo;</TD></TR><TR><TD CLASS="quote">They are the same.
I just measured an actual CTR throttlebody and it is 62mm.</TD></TR></TABLE>
Measure the part that fits against the intake manifold, not the mouth. The CTR throttle body is not the same as the ITR. I measure one out of a front clip straight from Japan... I am 100% sure they are not the same.
Old Apr 17, 2004 | 09:04 PM
JeffS's Avatar
Default Re: CTR TB vs. ITR TB (Hybrid93Eg)
You're right... it does taper. I don't want to remove it from the IM but it appears to taper to about 58mm.
Old Apr 17, 2004 | 11:02 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffS &raquo;</TD></TR><TR><TD CLASS="quote">You're right... it does taper. I don't want to remove it from the IM but it appears to taper to about 58mm.
Its not that bad, it tapers down to 60mm... But most people you see who "know" its 62mm, measured the wrong end. Even the ITR one tapers down, but it tapers down from a larger opening to 62mm.
Old Apr 18, 2004 | 12:48 AM
ej1times's Avatar
Thanks for all the info, next time I'll be more specific. From the posts I conclude that the B16B (CTR) TB is 62mm and tapers to 60mm and the B18C5 (ITR) TB is 62mm on the Intake manifold side. If this is correct, then what does the B18C5 (ITR) TB measure on the intake arm side or does it measure 62mm straight through? Thanks again for all the info.
ek2k
Dec 13, 2004 07:53 AM
EGkTiOn_CiViC
14
Nov 22, 2002 05:59 AM
ITR1071
May 20, 2002 10:40 AM
C4wrx
Apr 15, 2002 05:00 AM
