Turbo is glowing red
Old Apr 17, 2004 | 01:43 PM
Layziebtnh055's Avatar
Default Turbo is glowing red
im posting this for one of my buddies, he ran his car for a while the other day and he chacked under the hood and the turbo was glowing red, , ???why
HondaRcB's Avatar
Default Re: Turbo is glowing red (Layziebtnh055)
It was hot
Old Apr 17, 2004 | 01:51 PM
regime's Avatar
Default Re: Turbo is glowing red (HondaRcB)
its normal.
Old Apr 17, 2004 | 01:56 PM
ImportsCRX's Avatar
=\ turn off the neon's under the hood. lol kidding. Yeah man, it's running pretty damn hot. Ask one of your friends to touch it. rofl
Old Apr 17, 2004 | 01:58 PM
crxgator's Avatar
its a bomb...
Old Apr 17, 2004 | 02:13 PM
jedubz's Avatar
Default Re: (ImportsCRX)
I've seen some good pictures. Hmmm lets stick our finger in a turbine. Oh! It's gone!
Old Apr 17, 2004 | 02:16 PM
omahajim's Avatar
Default Re: (jedubz)
have ihs air/fuel ratio checked. he may be running lean. that spikes the exhaust gas temperatures. just checking the exhaust temp is useless. different engines will have different temps even when the air fuel ratio is correct.
Old Apr 17, 2004 | 02:24 PM
crxgator's Avatar
Default Re: (omahajim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omahajim &raquo;</TD></TR><TR><TD CLASS="quote">have ihs air/fuel ratio checked. he may be running lean. that spikes the exhaust gas temperatures. just checking the exhaust temp is useless. different engines will have different temps even when the air fuel ratio is correct. </TD></TR></TABLE>
so should i have my stock passat's a/f ratio check when it glows red hot at night...
Old Apr 17, 2004 | 02:39 PM
regime's Avatar
Default Re: (crxgator)
a/f gauges are crap.
if you aren't using a wide band they aren't telling you anything.
get it wide-band tuned
and if ya wanna touch the thing. i suggest yer tounge
Old Apr 17, 2004 | 03:15 PM
crxgator's Avatar
Default Re: (regime)
your tonge...
i heard if you put your **** on it, it grows 10 inches...
Old Apr 17, 2004 | 03:27 PM
ek_99_SiR's Avatar
acctually he may need a larger exhaust .. then it wont get as hot
Old Apr 17, 2004 | 03:51 PM
Discostud's Avatar
lmao at crxgator
green91's Avatar
ive got a good pic!
Old Apr 17, 2004 | 03:54 PM
crxgator's Avatar
Default Re: (green91)
nice pic...
for some reason i do want to touch it...
Old Apr 17, 2004 | 03:57 PM
Discostud's Avatar
i kinda wanna cook breakfast on it
Old Apr 17, 2004 | 04:16 PM
dr_latino999's Avatar
Default Re: (downset-crx)
Pretty....shiny.....
Damn, I seriously did not know a turbo could heat up that much under basic usage. Hell, I didn't know any part could heat up like that and maintain structual stability and such what.
Old Apr 17, 2004 | 04:28 PM
cloud806's Avatar
Default Re: (dr_latino999)
daym i knew turbos were hot but that picture makes it look crazy...
Old Apr 17, 2004 | 04:32 PM
Mr Furball's Avatar
Thank you for my new avater
Old Apr 17, 2004 | 09:00 PM
VTgringo's Avatar
Default Re: (Mr Furball)
more cooling.....good lord that things hot. I'm taking a class right now on compressor and turbine design. your compressor fins are really loosing there ability to handle stresses. Over time your blades will fail. Also, the high temperatures of the turbo is actually cooking the oil (the reason you bought that sweet over priced turbo timer). ahh yes and another problem. oil looses its properties at those high temperatures, or its ability to fight friction. this is also the same oil that is used to lubricate those expensive pistons you may have in your engine. my point is, this is something you should look into. Better cooling is your only friend.
and yes, lean conditions cause higher engine temps as well as more nox which will hurt emmissions.
Good luck, hope this helps
Old Apr 17, 2004 | 10:28 PM
FastAllmotorLsVtec
Guest
Posts: n/a
makes all the air hot that will suck
Old Apr 17, 2004 | 10:57 PM
koto SM2's Avatar
Default Re: (CrxStreetRacer)
Want to see more glowing red turbos? Watch the Porsches lap the track at the 24 hours of Daytona at night.
Old Apr 17, 2004 | 11:00 PM
koto SM2's Avatar
Default Re: (koto SM2)
Also, watch this dyno vid:
http://www.lingenfelter.com/Li...1.wmv
Old Apr 17, 2004 | 11:51 PM
Smokinsax's Avatar
The Boot
in that clip, that header heats up really quick!
Old Apr 18, 2004 | 12:02 AM
CWESTINAP1's Avatar
nice video clip
Old Apr 18, 2004 | 01:12 AM
RuthlessEF-9's Avatar
that would be a scary sight to see under the hodd
