NO VTEC HELP!!!!!!!!!!
Old Apr 17, 2004 | 12:24 PM
94turbolude's Avatar
Default NO VTEC HELP!!!!!!!!!!
ok before i say anything i will tell you that i have searched the site up and down and still had no luck!
I just did a swap into a 93 prelude that was an h23 and i installed the allmightly h22 and ecu both are jdm used parts... as the topic reads i have no vtec and have a 6500 revlimiter but no codes or C.E.L.! I have done all the wiring double and tripple checked the harness and pins, and have even gone to the extent to run new wired to the solenoid and switch...I have tried 2 other p13 ecus and no luck but i can use a p72 ecu and the rev limit is gone but still no vtec. This is the 4th swap of this kind that i have done and never had a problem like this. Could there be a pinout difference somehow in the harness? I am lost......... any help or ideas will be appreciated
Blake
Old Apr 17, 2004 | 03:04 PM
hondaZvic's Avatar
Default Re: NO VTEC HELP!!!!!!!!!! (94turbolude)
heres this ...
https://honda-tech.com/zerothread?id=828297
and that one will lead u to this one...
https://honda-tech.com/zerothread?id=164863
good luck, keep us posted
Old Apr 17, 2004 | 03:52 PM
zensoku207's Avatar
Have you tried using a prelude vtec harness??
Old Apr 17, 2004 | 05:49 PM
doublejz's Avatar
Default Re: (zensoku207)
pressure switch, oil pressure?
Old Apr 17, 2004 | 07:01 PM
zensoku207's Avatar
he said he ran those wires himself
Old Apr 18, 2004 | 07:01 AM
doublejz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zensoku207 &raquo;</TD></TR><TR><TD CLASS="quote">he said he ran those wires himself
ok great, did i say the wires to the pressure switch? i said the pressure switch, which could be bad not allowing vtec to engage, or could be a bad vtec solenoid. Make sure the screen isn't full of **** not allowing the oil to flow correctly
Old Apr 18, 2004 | 09:31 AM
zensoku207's Avatar
It's wierd theres no vtec, but you still don't get any celly cel's.
jdmh22:)
11
Feb 18, 2012 08:05 PM
jaybsmooth
Sep 24, 2006 03:19 PM
93accordcustom
Nov 16, 2005 07:49 PM
94turbolude
Apr 18, 2004 11:35 AM
99spanishGT
Dec 26, 2003 10:57 PM
