can somebody help me with this?!
Old Apr 17, 2004 | 10:12 AM
ls95hatch's Avatar
Default can somebody help me with this?!
no air is coming out of my vent when i turn them on in my 95 cx. the fuse is fine and theres on check engine light. whats my problem? i put this in the eg forum but nobody was helping. thanks
Old Apr 17, 2004 | 01:53 PM
zensoku207's Avatar
is the vent closed?
Old Apr 17, 2004 | 03:18 PM
ls95hatch's Avatar
Default Re: (zensoku207)
no, thanks tho, its all the vents, not hot or cool air. (i dont have ac)
Old Apr 17, 2004 | 03:23 PM
zensoku207's Avatar
maybe a plug came unplugged? does the fan itself turn on?
Old Apr 17, 2004 | 03:53 PM
VtecDeMoN's Avatar
Default Re: (ls95hatch)
Sounds like either a plug is loose on the fan motor or time to get a new one.
Brian
Old Apr 18, 2004 | 08:19 AM
ls95hatch's Avatar
Default Re: (VtecDeMoN)
wheres the plug?
Old Apr 18, 2004 | 08:58 AM
SkRiBLaH's Avatar
change out the vent spark plug
Old Apr 18, 2004 | 09:26 AM
zensoku207's Avatar
the what??
Old Apr 18, 2004 | 11:38 AM
ls95hatch's Avatar
i didnt know there was a vent spark plug. where is it located? is that the some plug somebody else told me to check?
Old Apr 18, 2004 | 08:25 PM
ls95hatch's Avatar
bump
Old Apr 18, 2004 | 08:45 PM
Mike@CCT's Avatar
Formerly Mike@TSR
ha. vent spark plug. good call. change the cap and rotor for the fan motor too.
Old Apr 18, 2004 | 10:23 PM
Thrillhouse's Avatar
Default Re: (TSRperf)
you dont have AC in your car? or your AC isnt working?
If you do have AC and its just not working start at the source, the compressor - make sure it is engaging when you turn your AC on. If that works touch each of the lines, the line coming out of the compressor should be hot, then it will go through your condenser that line should be warm, then it will go up to the firewall and into some sort of metering device (TXV, H valve not sure what ur car uses) then there should be a line coming out of the firewall also, that line should be cold. If all this checks ok then check power and ground to your blower motor, and the cables on your control panel.
If you dont have AC and air is not coming out of the vents then who the **** cares!
B20TRIZ
Mar 29, 2010 02:36 PM
EJ1 wilcox
21
Jan 7, 2008 11:49 AM
dps
Jun 19, 2006 02:35 PM
hybridpatient95
Oct 27, 2005 05:24 PM
fizzbob7
12
May 23, 2004 07:09 PM
