Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Fenders in STS
Old Oct 29, 2001 | 05:15 PM
RineRacing's Avatar
Default Fenders in STS
While driving my car on the streets between events I get fender rubbing on one rear fender. Within the STS rules can I only roll in the inner lip? I could always raise the rear suspension but I have seen other tegs lowered more then mine without getting rubbing, so what else can I do to prevent this rubbing?
15" Kosei K1 with Kumho 712's 205/50 38 offset
[Modified by Geratol, 6:43 PM 10/29/2001]
[Modified by Geratol, 12:27 PM 10/30/2001]
Old Oct 29, 2001 | 05:31 PM
Conechaser's Avatar
Default Re: Fenders in STS (Geratol)
how low are you? Are you sure you have the correct offset on your rims if you aren't lowered that much?
Old Oct 29, 2001 | 05:46 PM
RineRacing's Avatar
Default Re: Fenders in STS (94Accord)
I don't know how much lower the ride height is from stock but I can raise or lower 1.5" if I want. The offset is debatable but from most people I have heard that a 38 offset on a GSR should work.
Old Oct 29, 2001 | 06:30 PM
Conechaser's Avatar
i assumed 15" rims, is this correct? or larger?
Old Oct 29, 2001 | 06:52 PM
civicrr's Avatar
I have heard just the opposite on the offset. I was told that for lowered cars that the 42mm is better.
Old Oct 29, 2001 | 11:03 PM
DB2-R81's Avatar
25 Year Member
Default Re: Fenders in STS (civicrr)
I will second civicrr comment, wrong offset, use 42.
Old Oct 30, 2001 | 04:28 AM
CivicSiRacer's Avatar
Default Re: Fenders in STS (DB1-R81)
I 3rd that. 15x7" you should use a 42mm offset. The tire size is right.
Old Oct 30, 2001 | 05:44 AM
Shmeek's Avatar
Default Re: Fenders in STS (CivicSiRacer)
Having the same problem myslef, here's a stupid question. Can one change the offset without getting different wheels?
Old Oct 30, 2001 | 06:34 AM
celica73's Avatar
New User
Default Re: Fenders in STS (Shmeek)
You can use spacers to make the offset less, but the only way to increase the offset will involve precision milling of some metal. Not the best idea.
Alternatively, you could just put in stupid amounts of negative camber. With the tops of the wheels tipped in further, you will clear the fender wells.
5 or 6 degrees would make your car "HeLLa tIgHt!"
Scott
Old Oct 30, 2001 | 09:08 AM
Default Re: Fenders in STS (celica73)
Just sell the current rims you have and get ones of the right offset.
Old Oct 30, 2001 | 11:27 AM
RineRacing's Avatar
Well, CRAP. I spent hours looking into what offset to get. Tire Rack and other racers I know all said 38 so I got 38. I guess I might just brake down and raise the rear suspension 1/4 inch or so rather then buying a new set of rims.
I forgot to add, I'm just getting rubbing on one side but both sides are lowered equaly. So half my car tells me 38 is okay and the other half tells me otherwise .
[Modified by Geratol, 12:31 PM 10/30/2001]
Old Oct 31, 2001 | 06:39 AM
I actually put in 1/2" spacers for my lowering springs cause the tires I have rub a bit.
Old Oct 31, 2001 | 07:53 AM
Todd00's Avatar
I said I don't want a title!
Stock is 50mm. I don't know why they told you 38, but you will either have to dial in crazy camber or go up in ride height as the others have stated. Also, STS rules states that your wheels/tires cannot stick out beyond your fenders. I don't think 38mm in a 15x7 will, but it might be close.
Put those wheels on ebay and get the 45mm offset if you want to have the correct setup.
Old Oct 31, 2001 | 10:31 AM
fsp31's Avatar
Default Re: Fenders in STS (Todd00)
You could add another bumpstop. ;-)
I also had some fender rubbing problems, and was short on cash at the time. So, in search of an effective "ghetto style" solution, I bought a pair of bump stops at the dealership for about $7, slipped them onto the shocks, and that cured the problem. I was pretty concerned about what the added stops would do to my handling, potentially creating a seriously progressive rate "spring". But, I really didn't have any problems at all, even on my Hoosiers. BTW, there are "front" and "rear" bumpstops. The only difference is that the material on the rear stops is a bit softer than the fronts.
Old Oct 31, 2001 | 10:54 AM
WRXRacer111's Avatar
Umm... are you SURE the stock GS-R offset is 50mm? I had 38mm offset on my RS and never had a rubbing problem on the track when the wheels would get pushed up into the fenders.
Old Oct 31, 2001 | 10:58 AM
SJR's Avatar
SJR
Default Re: Fenders in STS (WRXRacer111)
all right, I just went out and took off the hub caps on my stock 1996 GS-R wheels, and lo and behold, the stock offset, as indicated on the rim, is 45mm.
so there.
[Modified by SJR, 7:59 PM 10/31/2001]
Old Oct 31, 2001 | 11:07 AM
Todd00's Avatar
Default Re: Fenders in STS (SJR)
Ok, so it's 45mm The R is 50mm, but then again I believe the wheelbase is a tad wider on the R.
Old Oct 31, 2001 | 11:29 AM
Actually they can protrude out from the fenders just to a point though like Street Prepared rules. The old STS rule of wheels sticking out was tossed out.
Old Oct 31, 2001 | 11:39 AM
RineRacing's Avatar
I think I'm going to try rolling the fender lip and raising the suspension before I even think about buying new rims. If I did go with the 45 offset I think the 7" wide tires would rub on the inside as I have seen with other cars.
Old Oct 31, 2001 | 04:42 PM
Todd00's Avatar
No, they won't. I have 15x7 45mm Koseis on my R with 225/50/15 slicks and I get *no* inside rubbing at all, and those slicks are a lot wider and taller than a 205/50/15 tire.
And the wheel protruding rule was thrown out of STS/STR? Cool. So I can get those 13x7.5 rims that I have been eyeing.
deck1
Oct 23, 2006 09:32 PM
enviousdm
Apr 11, 2006 05:42 PM
stealthhatch
May 4, 2004 02:46 PM
XR4racer
Jul 19, 2002 05:17 PM
typer77
Feb 16, 2002 09:07 AM
