ZC vs Z6
I have a eg coupe and I am tired of my ragged out z6, I have only enough "grip" to buy one of these motors and dont know which of the two would be the best choice. So I guess the question really comes down to, 2ND GEN 1.6L DOHC vs 1.6L SOHC VTEC. as much info as possible would be greatly appreciated.
Modified by Random guy at 2:09 AM 4/20/2004
you can also find matt on ebay his user name there is "guit-guit" and he sells SOHC ZC vtec's and sohc ZC's and dohc zc's
so on ebaymotors.com type in zc and im pretty sure most of the zc parts are his. hes a good guy. i bought my sohc zc vtec from him!
Much thanks to Dave, that static X rip off ha ha, and Celtic but i would also like to know if my after market header will fit the zc, them being both d series engines i would think so but by now we all no the variable of z6 to zc heads.
the sohc zc vtec pushes 130hp. and it has vtec. i dont know if the tq spec's are the same as the dohc but its the same hp. all d series headers fit as long as they are SOHC. the ZC that is DOHC has larger ports then the sohc's i *think* someone correct me please..
swapping a d16z6 out for a ZC is not worth it in my opinion.
The two motors are very similar in terms of power output, and actually if I had to choose one, i'd lean towards the Z6, which you already have.
unfortunately you're car feels sluggish because its an ex and is heavy as ****.
dseries has potential.. but it's strength is in ease of use, and low price, not overall power output, which is why you'd want one in a lighter car.
turbo is your best bet.
and actually would do quite well, giving you plenty of torque to pull that coupe around.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad »</TD></TR><TR><TD CLASS="quote">swapping a d16z6 out for a ZC is not worth it in my opinion.
and actually would do quite well, giving you plenty of torque to pull that coupe around.</TD></TR></TABLE>
true. and the z6 has more aftermarket support!
MidwestSi
Sep 8, 2004 01:59 PM
vtec > non vtec but dohc or dohc > single vtec ?
