d16a6 swap question...
Old Apr 16, 2004 | 08:09 PM
h22squeaker's Avatar
Default d16a6 swap question...
just picked up a 88 crx si, its got a d16a6 in it......can anyone tell me if a d16z6 or d16y8 head will swap onto the block? also, will the valve springs/locators/retainers from a d16z6 or d16y8 fit into the d16a6 head....i just want to upgrade the valve train if possible, wondering if i have to swap a new head or whole motor in this thing....thanx
Old Apr 16, 2004 | 08:25 PM
slowcarguy's Avatar
Default Re: d16a6 swap question... (h22squeaker)
Both heads will work but you have to take out the oil jet from the a6 block if you do the swap
Old Apr 17, 2004 | 07:00 AM
busychild's Avatar
just like he said.
Just to temp you, the a6 head can support more radical cam profiles over the VTEC heads. If you plan all-motor as I do, it gives you an option over getting a different head . I have heard....the Vtec cams are a bit harder to tune also. Good luck!
shawnperolis
17
Aug 30, 2013 11:19 AM
HaTcHZiLLa
Aug 29, 2005 08:16 PM
GroundZer0 336
Mar 4, 2003 04:31 PM
