Msd Pills?
Old Apr 16, 2004 | 05:57 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Msd Pills?
what are msd pills i was thinking about getting a msd 6al with cap and coil but first is the pill when the inginte of the msd happen like it starts and hads more spark and how long does it last?sorry if i dont make sense
Old Apr 16, 2004 | 06:07 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: Msd Pills? (CrxStreetRacer)
zzz
Old Apr 16, 2004 | 06:17 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Old Apr 16, 2004 | 06:24 PM
david@didrace.com's Avatar
If you're asking what the MSD pills are for. They are different resistors used to control RPM based activated MSD devices.
Old Apr 16, 2004 | 06:27 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: Msd Pills? (10-94-55)
ok i know that is what its say what does that mean?
like the pills for the msd 6al
Old Apr 16, 2004 | 06:33 PM
On the 6AL they are used to control a rev limiter.
Old Apr 16, 2004 | 06:35 PM
FastAllmotorLsVtec
Guest
Posts: n/a
ok thanks so when does the whole system start up then when does it give better spark?
Old Apr 16, 2004 | 06:44 PM
If it's installed correctly, it starts working immediatly once the ignition switch is on the start position. You may/may not notice a difference on a stock engine. If you have the rev limiter set w/ a pill though you can check that thats working be seeing if it limits the engine at all.
Old Apr 16, 2004 | 07:01 PM
FastAllmotorLsVtec
Guest
Posts: n/a
it will be on a b18c5 not stock engine!
97tegblk
Sep 11, 2007 07:03 PM
Jockobo
Jun 30, 2004 01:46 PM
mrDFWmechanic
Dec 12, 2003 12:56 PM
Rhetoric
Dec 17, 2001 08:08 PM
