Catchcan setup for ls/vtec???
Old Apr 16, 2004 | 02:08 PM
tnsxsear1's Avatar
Default Catchcan setup for ls/vtec???
Does any1 know the website which explains how to add a pcv/catchcan system to the ls/vtec since its completely eliminated. Talks abot tapping a nipple behind the block, etc... Thanx -Paul
Old Apr 16, 2004 | 06:59 PM
na200whp's Avatar
Default Re: Catchcan setup for ls/vtec??? (tnsxsear1)
http://www.c-speedracing.com/h...n.php
Old Apr 16, 2004 | 09:09 PM
zensoku207's Avatar
where on the back of the block is the other line attached to? I assume it replaces the little black box under the IM.....
Old Apr 16, 2004 | 10:41 PM
krazie1's Avatar
BANNED
Default Re: (zensoku207)
why don't u guys check on the Z10 or the endyn ones they totally give u step by step instructions or help on line ot install
I am waiting to order mine from Z10
but is someone interested in a cusco catch can
I got one that well not going to need anymore, right
check there web site or the sponsor classfied section for dealer
Old Apr 16, 2004 | 10:43 PM
zensoku207's Avatar
Are they really that important besides the stock one?
Old Apr 17, 2004 | 08:03 AM
tnsxsear1's Avatar
Theirs no place to run the lines in a ls/vtec. In b16 motors the pcv system is on the block and in LS motors the system is in the head. So when you do an ls/vtec theirs not one anywhere.
Old Apr 17, 2004 | 09:21 AM
na200whp's Avatar
http://www.theoldone.com/ this site offer a great kit . has every thing you need to hook it up i have one on my car and i love it
Old Apr 17, 2004 | 09:56 AM
baphomet's Avatar
Default Re: (na200whp)
Read these threads and all the links:
https://honda-tech.com/zerothread?id=722482
https://honda-tech.com/zerothread?id=687222
Everything you need and cheap - don't waste your money on that bling edyn kit when you can get the EXACT SAME functionality for ~30 or less.
Old Apr 17, 2004 | 10:43 AM
Highrevs99's Avatar
The bosses already in the ls blocks for line and black box . If you have a b18A it will already have both but if its a B then all you have to do is tap out the boss on the left rear upper corner by the deck . You can get a catch can for 38.00 from JAZ . I ran mine open filter but a pcv valve can be put in the top if desired .
TRF #001
Mar 28, 2005 04:45 PM
GEN2TEG
Nov 20, 2002 09:43 PM
Moog
Nov 15, 2001 05:55 AM
