Hesitation in acceleration
Every once in a while my accord will hesitate from about 2k-3k rpm, I could be flooring the gas and it would only rev up extremely slowly. But most other times it just revs up normal. I have no idea why it would do this, because I've never had any problems before, and it only does this once in a while.
Anyone know whats wrong and how to fix it? Thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FatJoe »</TD></TR><TR><TD CLASS="quote">youre flooding it. flooring it gets you nowhere... </TD></TR></TABLE>
what is that suppose to mean?
dirty injectors? dirty fuel filter? spark plugs? ignition timing? clogged egr? clogged cat? air filter? loose throttle cable? thats all i can think of, just woke up ;[ sorry..
i have the same exact problem with my 90' integra and this has nothing to do with the intake/exhaust restriction because i for sure have none. But my guess is it is a fuel system problem just by the feel of the car as if it were running incrediably lean. so far in search of the problem i have replaced every single ignition component and it persists so to keep it cheap start with fuel system and dont start replacing parts untill you have checked all possibilitys cause u dont wanna spend cash aimlessly which problems like this often lead to.
just cleaned the air filter on the intake.. damn that helped a lot, but it still has quite a rough idle.. I'm just glad the engine isnt cutting off anymore when I'm idling.
