rear tail lights won't light up, help before I'm rear ended!!!
dont know when this happened but rear turn signals blink and tailights light up when I turn on my headlights. My brake lights wont do a damn thing at all. The bulbs are fine and the 10 amp fuse is ok cause it runs my gauge cluster. IS there a relay or a switch on the actual brake pedal to know when it is depressed?
help me out
help me out
I know that there is a button behind the brake pedal that when you push down on the brake that button is pressed in causing the lights to light. You might want to take a test light and check if there is any power coming out of the button. If there is then it might be a relay but I wouldnt know which one it is.
theres a break switch on the arm of the brake pedal check that. youll see it it looks like a button. check that our that might be it
found out it was a fuse under the hood.
all is good now. To think I had no tailights for a week
flatblk
Nov 23, 2006 05:14 AM
