Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Vtec in a Crv
Old Apr 16, 2004 | 03:54 AM
SprayinCX's Avatar
Default Vtec in a Crv
okay if you where to use a actual Crv and wanted to put a vtec head in it what ecu would you run?
i was thinking that you could use a 99 si ecu and then just add the knock sensor wire plus the sensor itself.
what do you guys think?
Old Apr 16, 2004 | 05:17 PM
showtymers619's Avatar
* B A N N E D *
Default Re: Vtec in a Crv (SprayinCX)
if its a manual then a 99 ecu would be fine.. but if your an auto.. then a vtec controller would work just as well..
im on the verge of doing my CRV-tec turbo
Old Apr 16, 2004 | 08:35 PM
SprayinCX's Avatar
Default Re: Vtec in a Crv (ShowTymers619)
nice a turbo crv/tec. keeps us updated on the project
Old Apr 17, 2004 | 02:09 PM
Berman's Avatar
if it's the B20b/B18b CRV, Use a 93-95 DC2 two row ecu (auto or man, whichever you have), plugs straight in and the only fault code is for the vtec solenoid, so just run a wire from there to ecu easy
Old Apr 17, 2004 | 02:20 PM
* B A N N E D *
Default Re: Vtec in a Crv (Berman)
the plugs are different wont work different obd's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Berman &raquo;</TD></TR><TR><TD CLASS="quote">if it's the B20b/B18b CRV, Use a 93-95 DC2 two row ecu (auto or man, whichever you have), plugs straight in and the only fault code is for the vtec solenoid, so just run a wire from there to ecu easy </TD></TR></TABLE>
Old Apr 17, 2004 | 02:42 PM
Berman's Avatar
Hmmm, my bad. What OBD is the CRV? Mines OBD1 and uses the same loom as the early JDM DC2 minus the vtec solenoid wire as I've tried this already for a B20vtec conversion. Maybe your USDM DC2's ecu is different to the JDM ones?
Sorry, I'm not up to date with the USDM stuff
Old Apr 17, 2004 | 03:22 PM
* B A N N E D *
not im actually using the actual CRV which is obd2
Old Apr 18, 2004 | 03:52 PM
* B A N N E D *
Default Re: Vtec in a Crv (IMOTEPHT)
its an auto.. kinn ahard to find auto gsr ecu
Old Apr 25, 2004 | 11:20 AM
xplanetearth420x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SprayinCX &raquo;</TD></TR><TR><TD CLASS="quote">nice a turbo crv/tec. keeps us updated on the project</TD></TR></TABLE>
and post a lot of pics
Old Apr 25, 2004 | 12:06 PM
* B A N N E D *
Default Re: Vtec in a Crv (xplanetearth420x)
will do.. in a few days im doing the head swap first i shall put pix up...
612tunerh22
May 30, 2008 01:23 PM
beefjerky
Oct 22, 2007 10:34 AM
PHAT-INTEGRA
Aug 23, 2005 08:57 AM
dat_flip
Apr 14, 2005 12:55 PM
EzKV
Jul 15, 2003 11:05 PM
