?s about p08 ecus
ok just curious a friend of mine has a d15b vtec swap in his crx. well theres a drivability problem. you give the car more than 75% throttle the car feels like it stalls then after the rpms drop it will pick back up and go. but from what the ecu is sayin its throwin 19 the automatic transmission lockup control valve?????? at first we thought it was the cyp #9 code but there is one long flash before the 9 fast flashs. so it throwin a #19 wtf.... is there an automatic p08 ecu ? another question when you jump the diagnostic plug to see the fault codes flash does it make any difference if you drive around with the plug still jumped? well everthing has been checked a number of time the dizzy has been switched the ecu switched but still the codes still flash and yes try reseting the ecu a number of times..... its also using the boomslang jumper harness... i dunno any help .....thanxs
