Crankshaft removal. help plz
Old Apr 15, 2004 | 09:20 PM
SunkistRex's Avatar
Default Crankshaft pulley removal. help plz
ok i cant get the fvcker loose. I tried to stick a 3/8 extension in the holes and it keeps turning. I dont have a air ratchet or anything just basic 1/2 ratchet and 17 mm... any ideas?
Modified by Projekt X at 4:40 PM 4/17/2004
Old Apr 15, 2004 | 10:00 PM
CRXDrew's Avatar
Do a search, this has been explained on many occassions.
Old Apr 15, 2004 | 10:02 PM
1990civicsiguye's Avatar
Default Re: (CRXDrew)
if you know how to do it just tell him it took you longer to write do a search ....... **** searching from now on ill never search again.......... god i hate that **** about this board.........
Old Apr 16, 2004 | 04:37 AM
keithv's Avatar
Default Re: (1990civicsiguye)
Projekt X, are you talking about the pullet on the crankshaft or the crankshaft itself?
Old Apr 16, 2004 | 07:41 AM
you must be talking about the pully i think
you could put a screwdriver in the flywheel from the underside of the car then that will stop it from turning and it should come off with a little pushing and pulling.....
Old Apr 16, 2004 | 11:16 PM
SunkistRex's Avatar
yea im talkin about the pulley sorry about not specifyin, i tried the flywheel thang, but the screwdriver justmoves and falls out when i try to spin it.. its agrivating... i just gave up for now untill i can find a way ...
Old Apr 17, 2004 | 05:36 AM
ScottEK's Avatar
Default Re: (Projekt X)
It's tought without air tools, but if you can find a friend with a compressor and a good impact it will come right off and you wont have to deal with holding the flywheel side.
Old Apr 17, 2004 | 12:41 PM
SunkistRex's Avatar
Default Re: (beta13)
i dont have any friends with air tools... how do i get it to stop spinning? please help im desperate
Old Apr 17, 2004 | 06:37 PM
SunkistRex's Avatar
Default Re: Crankshaft pulley removal. help plz (Projekt X)
ok guys after 2 hours of searchin on google.. and multibule sites... i got so pissed off i went out and bought a air compressor and a air gun.. lol still did not break it loose.. this point im so frustrated im about as red as my car... i rip down my privacy fence and use the hinges, cut the triangle off the rectange on the bracket.. i wedged that bitch in there and i grabed a 20 foot pole.. (LOL) i had to take my hood off.. but i got that bitch loose.. i had to get a step ladder and launch off of it but it finally broke loose!!!! i got the new timing belt on but as i looked at my crankshaft pulley i immeditly went.. WTF!?! there is a notch in the pulley but! there is a notch in the crankshaft gear itself.. well both of them go in the metal instead of comin out to slid into each other.. anyway i figured it out and got everything back on.. thx for the advice and help i appreciate this so much... thanks guys!
Schultzie
Jan 16, 2008 09:41 AM
ITR-2001
Aug 18, 2006 12:57 AM
jefe
14
Aug 12, 2004 05:51 PM
altoid
Jun 27, 2003 12:34 AM
protocol_droid
Feb 21, 2002 10:23 AM
