Portable Air Compressors? Which one?
Old Oct 29, 2001 | 12:07 PM
itr501's Avatar
Default Portable Air Compressors? Which one?
What should I look for in a 12v portable air compressor? I see that the PSI ranges from like 250 to 300 I think. What Brands are good? and what kind of specs should I look for.
Dont want an air tank event hough it's faster because I don't want to lug that thing around.
Old Oct 29, 2001 | 12:25 PM
itr1275's Avatar
Default Re: Portable Air Compressors? Which one? (itr501)
If your filling your tires, it doesn't make much difference. If you want to run air tools, which is not likely to work on a 12V system, you will need to look at CFM. Typically the $300 Craftsman ones are pretty good, but they run on 110AC.
Old Oct 29, 2001 | 12:49 PM
ThePunk's Avatar
Default Re: Portable Air Compressors? Which one? (itr1275)
I found a 12V compressor at our local "Home Center" for $50! It is battery powered, and works perfectly for Auto-X/Drag tire purposes. At the last auto-X it got passed around from person to person all morning, and still had plenty oof juice left.
It doesn't have a model number on it, but is made by campell hausfield.
(You can use the internal-rechargeable battery as a portable 12V supply as well.)
Old Oct 29, 2001 | 03:38 PM
SleepyR's Avatar
New User
check walmart I got a cheap a$$ jack that came w/ a compressor for $25. the compressor works good and works by just plugging it into to your ashtray thingy
Old Oct 30, 2001 | 05:48 PM
itr501's Avatar
Default Re: Portable Air Compressors? Which one? (SleepyR)
are these ok for auto-x?
Old Oct 30, 2001 | 06:00 PM
ThePunk's Avatar
That appears to be slight overkill for just Auto-X. But if the price is right, and your willing to drag it to the track with you, It would be fine.
Here's what I bought.
(And it works great for charging up the spud-gun too!)
[Modified by ThePunk, 9:17 PM 10/30/2001]
Old Oct 30, 2001 | 06:13 PM
Bob#455's Avatar
Default Re: Portable Air Compressors? Which one? (ThePunk)
Hehe, I remember that... Thanks Punk!!
Old Oct 30, 2001 | 06:27 PM
davidnyc's Avatar
i have the same one as ThePunk. Once your tires are pumped up, you can use this thing for 20+ times to adjust pressures on one charge. I bought it at Home Depot for $40-$50.
Gironamo
Jun 27, 2011 08:57 AM
slacks
Feb 5, 2008 03:27 PM
drunknbass
Jul 2, 2004 01:48 PM
dabrown
Mar 15, 2004 09:01 AM
Soon_2b_evil
Aug 18, 2003 07:27 AM
