EGR wire on OBD2 Accord ECU
Old Apr 15, 2004 | 05:51 PM
HAccord96's Avatar
Default EGR wire on OBD2 Accord ECU
Does anyone know which pinout on an OBD2 F22 vtec Accord ECU is the EGR valve wire? I really need to know. Thanks in advance.
Old Apr 15, 2004 | 06:41 PM
Chiovnidca's Avatar
Default Re: EGR wire on OBD2 Accord ECU (HAccord96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HAccord96 &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know which pinout on an OBD2 F22 vtec Accord ECU is the EGR valve wire? I really need to know. Thanks in advance.</TD></TR></TABLE>
c28 = ref voltage
c18 = ground
c6 = sensor input
b7 = valve control
Old Apr 15, 2004 | 07:41 PM
HAccord96's Avatar
Default Re: EGR wire on OBD2 Accord ECU (Chiovnidca)
So what wire should I use to hook the EGR up to the A11 wire on a P13 ecu?
Old Apr 15, 2004 | 07:52 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HAccord96 &raquo;</TD></TR><TR><TD CLASS="quote">So what wire should I use to hook the EGR up to the A11 wire on a P13 ecu?</TD></TR></TABLE>
I don't know. What's the a11 wire for? Power, ground, sensor or lift?
Old Apr 15, 2004 | 08:31 PM
HAccord96's Avatar
Oh, it's probably for the sensor.
chris89
Apr 20, 2017 04:09 PM
andyvaj
Aug 11, 2007 09:24 AM
B18Cej1
18
Mar 2, 2004 03:33 PM
PhazedSI
Feb 14, 2004 09:47 PM
dingusjt
Nov 13, 2003 10:18 AM
