Redrilling rotors...
Old Oct 29, 2001 | 11:33 AM
Jordan_4WS's Avatar
New User
Default Redrilling rotors...
Im thinking of upgrading my 4g lude to NSX brakes. Anyway, I think it would be better to use an NSX rotor over a vtec rotor since it is a bit wider and I think would reduce warpage (sp?) alot. The issue is that the nsx is 5 lug and my lug is 4x114.3. Anyway, I am wodnering if there is anyway to have the rotors redrilled to fiit the 4 lug. Anyone know? How much would it cost?
Old Oct 29, 2001 | 11:55 AM
4doorH22's Avatar
Default Re: Redrilling rotors... (Jordan_4WS)
Ummm no. If it were that easy we'd all have NSX brakes.
Old Oct 29, 2001 | 12:29 PM
typer_801's Avatar
Default Re: Redrilling rotors... (4doorH22)
Hmmm, I thought I remembered hearing the Accord Wagon's had 11 inch front rotors and were also 4x114.3mm. That's where the calipers came from on the ITR's (if I remember correctly).
Old Oct 29, 2001 | 12:32 PM
Jordan_4WS's Avatar
New User
Default Re: Redrilling rotors... (typer_801)
The prelude vtecs also have 11.2 rotors. THe problem is they are not as thick as nsx.
Old Oct 29, 2001 | 12:37 PM
Jordan_4WS's Avatar
New User
They dont have a machine taht they can bolt the rotor onto to redriill it evenly?
Old Oct 29, 2001 | 03:16 PM
Honda318dx's Avatar
Its not worth it at all, unless you take your car on racetracks, if you wanna stop better, save yourself a lot of money and just get some kickass pads
Old Oct 23, 2006 | 08:51 PM
repn a lude's Avatar
Default Re: Redrilling rotors... (Honda318dx)
prelude brakes will keep you clamped!!!
Old Oct 23, 2006 | 09:07 PM
Rosko's Avatar
Default Re: Redrilling rotors... (repn a lude)
It can be done, (the drilling anyway) as long as the nsx rotor is on the same bolt circle (the 114mm dimension) otherwise the fifth hole will run into one of the other 4. if its 5 by 114 then you will actually reuse one of the original 4 and then drill 4 new ones. I guess you're going the other way,5-4, but it still works out the same.
If I still had the fixture I'd do it for ya, but I threw it out long ago. I took 4th gen rotors and put a 5 bolt pattern into it for my front wheels.
Old Oct 23, 2006 | 09:35 PM
Hawkze_2.3's Avatar
If you want to do it then just take them to a machine shop and have them drilled. Seems kinda overkill though....
Old Oct 23, 2006 | 09:50 PM
Rosko's Avatar
Default Re: Redrilling rotors... (Hawkze_2.3)
does the caliper even fit? is it the right offset? those imo would be the biggest probs.
Old Oct 23, 2006 | 09:58 PM
Hawkze_2.3's Avatar
Default Re: Redrilling rotors... (Rosko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko &raquo;</TD></TR><TR><TD CLASS="quote">does the caliper even fit? is it the right offset? those imo would be the biggest probs.</TD></TR></TABLE>
Very good point
Old Oct 24, 2006 | 01:02 AM
soundbomber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by repn a lude &raquo;</TD></TR><TR><TD CLASS="quote">prelude brakes will keep you clamped!!!</TD></TR></TABLE>you brought back a 5 year old thread....
nsx brake swaps have been done NUMEROUS times since this thread was created
Scotty Dosent Know
Suspension & Brakes
37
Aug 16, 2008 10:26 AM
20vsleeper
Jul 25, 2007 09:14 PM
Solscud007
Aug 14, 2006 04:12 AM
riceball777
Jul 22, 2003 03:49 PM
GoldenONE
May 16, 2003 11:43 PM
