Anyone with Ls????
Old Apr 15, 2004 | 03:42 PM
Lshatchy91's Avatar
Default Anyone with Ls????
Anyone have an ls swap into their hatch or crx...... if so does it run rich ... i hear its setup rich..mine blows a lil smoke when shifting.......?????
Old Apr 15, 2004 | 03:43 PM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
are u using stock exhaust system?
Old Apr 15, 2004 | 05:55 PM
Lshatchy91's Avatar
Default Re: (dgonzals)
no..... i have custom 2 1/2 piping
Old Apr 15, 2004 | 06:20 PM
jedubz's Avatar
There's a million and one reasons that could be happening. What ECU are you running? Are you running a fuel pressure regulator? What color is your oil? What fuel pump? etc etc etc. Explain your set up.
Old Apr 15, 2004 | 07:18 PM
Lshatchy91's Avatar
Default Re: (jedubz)
pr3 ecu..... black oil......everything else is pretty much stock
Old Apr 15, 2004 | 07:20 PM
Malgerus's Avatar
Default Re: (Lshatchy91)
You're running a B16 PR3 ecu with a non vtec LS motor? Step number one: get the right ecu!
EDIT: And oil shouldn't be black...
Old Apr 15, 2004 | 07:38 PM
jedubz's Avatar
Default Re: (Mr. S)
Oil being black = change it.
PR3 ECU = Lean as hell VTEC, going to throw codes.
I'm not sure if the fact that it would throw a ton of codes because you're not using it with a VTEC head means that it's going to run on limp (hella rich mode).
Either way, get yourself a PM6 or a PR4, sell that PR3 on Ebay or save it for later...
But first things first CHANGE YOUR DAMN OIL BOY!
Old Apr 17, 2004 | 01:26 AM
Blind-Fashion's Avatar
lol.. you dont run on "limp" mode.. it just throws a
21
22
and knock..
wont run lean at all either on a stock ls..
chrispaugh
Nov 10, 2009 12:46 PM
allnaturalb16
Jan 14, 2007 04:02 PM
jacobolito
Dec 30, 2006 08:04 AM
SuperSi
15
Jan 4, 2006 07:37 PM
SiRk
Nov 8, 2005 05:52 AM
