DeCaRbOnIzInG HoNdA MoToRs
i had a similar situation when i failed my smog check a lil while ago. Go to any GM dealership and get a bottle of their "top engine cleaner." It does work!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dgonzals »</TD></TR><TR><TD CLASS="quote">have u tried stream washin?...i have to do that....my motor is thilfthy....</TD></TR></TABLE>
i think he means the inside...
i used ATF before, i couldnt tell the difference...
Spray water into your intake, don't pour it in. Get a mist bottle, spray it into your intake while you hold the rpms high. This will steam clean the inside of your engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx »</TD></TR><TR><TD CLASS="quote">Spray water into your intake, don't pour it in. Get a mist bottle, spray it into your intake while you hold the rpms high. This will steam clean the inside of your engine.</TD></TR></TABLE>
Coolent works the best. a nice steady mist.
but don't pour it. ThAtS NuTS!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X-Static »</TD></TR><TR><TD CLASS="quote">did you suck it in through the vacuum line?</TD></TR></TABLE>
yea through the brake booster line, plus in the oil and in the gas.
i'm doing it agian this weekend,cuz i know there's a LOT more carbon in there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic138 »</TD></TR><TR><TD CLASS="quote">Seafoam it. just seafomed mine last weekend, and i could tell a big differance after using it.</TD></TR></TABLE>
A little warning to all, seafoam does work but it also has a down side that sometimes causes major damage. I have seen a lot of people poor this into there engine and then ending up paying major money for problems it caused such as bent valve and blown head gaskets.
A little warning to all, seafoam does work but it also has a down side that sometimes causes major damage. I have seen a lot of people poor this into there engine and then ending up paying major money for problems it caused such as bent valve and blown head gaskets.</TD></TR></TABLE>
I have never heard of problems if you do it properly as the can says, as with alot of things if you dont folow instructions problems will arise but I am curious to why these people had problems from using seafoam? Do you know what they did wrong, I would like to hear what people did to cause a problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erikiksaz1 »</TD></TR><TR><TD CLASS="quote">How does the top engine cleaner work? And on a 14 year old engine, how much of a difference would it make?</TD></TR></TABLE>
Its in a bottle and just pour it in when your tank is near empty, then fill with a fresh tank of gas. Run that tank down, then refill. I didnt really notice a difference but my NoX numbers didn't lie.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda »</TD></TR><TR><TD CLASS="quote">
I have never heard of problems if you do it properly as the can says, as with alot of things if you dont folow instructions problems will arise but I am curious to why these people had problems from using seafoam? Do you know what they did wrong, I would like to hear what people did to cause a problem.</TD></TR></TABLE>
Do a search on here for seaform, you should be able to find some horror stories. As far as the ones I have seen in person, the people told me they followed the directions and when they shut the car off and turned it back on the car was acting up. Turned out to be the head gasket.
Get ready for a long read
https://honda-tech.com/zerothread?id=755765
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
forget my earlier comment...i have to ask my friend what he just put in his yesterday....he put some stuff in the cleans carbon deposits in the motor...he did it when he did his oil change....he put some in his gas tank and then his oil resevoir....i read the bottle it states it cleans the whole engine system of deposits up to the fuel injectors.....will get more info later....thanks crxgator for putting me in my place...hahah
http://runrite.com/industry/products01e.htm
i use the 9600, it works great... u can smell the crap coming out of the exhaust, and def. notice a power increase if the car is really bad to begin with.
call your local diesel truck repair facility and tell them what you are trying to do. they will have some stuffon the shelf to help you out. if you think that gas engines get gunked up, you have never seen the inside of a diesel.
