CRX REVS HIGH
Old Apr 15, 2004 | 12:44 PM
91CRXsiR's Avatar
Default CRX REVS HIGH
Hey guys, my car is revin at like 2k at idle? sometimes it revs at like 1500. but there are no vacume lines unpluged or anything. any one have any ideas?? its a 91 crx dx. thanks alot
Tyler
Old Apr 15, 2004 | 12:47 PM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
check the idle adjustment screw....thats all i can think about....lets start with that...
Old Apr 15, 2004 | 01:02 PM
CsRiX's Avatar
Default Re: CRX REVS HIGH (91CRXsiR)
any codes?
my 88crx si was doing this 3 months ago. it turned out to be something wrong with my coolant system. Air bubbles were getting into the coolant lines and thats what was causing it to rev. hope this helps a little.
good luck
Old Apr 15, 2004 | 01:50 PM
riceburners1's Avatar
does this happen if u let it idle for a while....once mine warms up it usually goes back down to good old 750 RPMS
Old Apr 15, 2004 | 04:44 PM
91CRXsiR's Avatar
so iv been workin wit her for a while now, i had previously: blead the coolent system, there are no codes, but the prob no more is the idle at 2k. now it likes to fluctuate from 1000 - 1800 rpm. my teacher told me to check the timming on the cam, i was off a tooth actualy. so i turned it to the correct tooth. started it up, ran fine, my throttle cable was loose so my boy tightend it for me, just so there wasnt any slack, then it started flutating again. there are no codes, its drivin me crazy, i can drive it, but i cant take off, like i cant creep, it bucks, because it flutates, but i found if i unplug the Idle Air controle valve, then it doesnt flutuate any more, it just idles at 1100rpm. then after 3min. it starts doing it again. PLEASE HELP ME!!! i need to go home tomarow for the weekend from college home is 3hours away. any help would be great. IM me im on all the time!!!! CRXsiR84 is my AIM sn.
Tyler
Old Apr 15, 2004 | 06:13 PM
cstay's Avatar
BUMP
Old Apr 15, 2004 | 06:21 PM
shaddr3's Avatar
Default Re: CRX REVS HIGH (cstay)
mine idles at 3kish... then after u put it in 1st gear and drive a tiny bit, and back in neutral, it revs from 500 then up to 1k, then to 500... so its like VRROOOm mmmm VRROOOOMMm mmmmmm VRRROOOOMMMmm . I gotta fix it.
Old Apr 15, 2004 | 06:59 PM
cbrodac0424's Avatar
Default Re: CRX REVS HIGH (shaddr3)
try the tps connection it might be loose that was the case in my 89 civic hatch just an idea
Old Apr 15, 2004 | 07:05 PM
91CRXsiR's Avatar
na the TPS is fine i checked that
HBK
23
Nov 17, 2010 04:59 PM
krysted9354
Classic Hondas
Jun 4, 2009 04:49 AM
DAJay93
Nov 30, 2007 11:40 PM
looxs
Nov 1, 2006 09:09 AM
BWP87CRX
Mar 2, 2003 06:20 PM
