ok to switch 4-1 to 4-2-1?
Old Apr 15, 2004 | 11:19 AM
accord745's Avatar
Default ok to switch 4-1 to 4-2-1?
my f22b2 [5th gen non-vtec] has an oem 4-1 exhaust header (or so i'm told - i haven't taken off the heat shield yet).
when buying an aftermarket piece, is it necessary to stick with a 4-1 design or can i switch to a 4-2-1 design?
if i switched to a 4-2-1, would i lose or gain overall performace?
Old Apr 15, 2004 | 01:30 PM
ChaosUnbound's Avatar
Default Re: ok to switch 4-1 to 4-2-1? (accord745)
no you don't have to stick with the 4-1 and the generaly the 4-1 gives you better low end and the 4-2-1 gives you better high end so its up to your tast
Old Apr 15, 2004 | 02:09 PM
i3igpete's Avatar
Default Re: ok to switch 4-1 to 4-2-1? (ChaosUnbound)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChaosUnbound &raquo;</TD></TR><TR><TD CLASS="quote">no you don't have to stick with the 4-1 and the generaly the 4-1 gives you better low end and the 4-2-1 gives you better high end so its up to your tast</TD></TR></TABLE>
you've got it backwards man. look at how race headers are constructed, and they are made for power only in the top end.
Old Apr 15, 2004 | 02:42 PM
spankey167's Avatar
Default Re: ok to switch 4-1 to 4-2-1? (i3igpete)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i3igpete &raquo;</TD></TR><TR><TD CLASS="quote">
you've got it backwards man. look at how race headers are constructed, and they are made for power only in the top end.</TD></TR></TABLE>
Correct
Old Apr 15, 2004 | 08:32 PM
my bad im mixed up
Old Apr 15, 2004 | 08:45 PM
1illAccord's Avatar
yup...u'll be fine with a 4-2-1.
Old Apr 16, 2004 | 04:11 AM
cleanaccord1997's Avatar
yeh switch and a 4-2-1 will slightly broden your powerband
Old Apr 16, 2004 | 08:06 AM
Mike813's Avatar
yep, just go to a junk yard and pick up a EX manifold, along with the a pipe.. and 4-2-1 is all yours.... and 5th gen headers ARE interchangeable... just need to extend the o2...
Nicks95GSR
Mar 22, 2007 10:16 AM
Integra_RS
Dec 29, 2004 12:22 PM
JuanK20
Dec 27, 2004 09:52 PM
jdmCivic925
Aug 3, 2004 04:03 PM
allicedout
Jun 24, 2004 06:51 AM
