m/t 22x8x15s what tire pressure should i go with?
Old Apr 15, 2004 | 09:33 AM
jdmekcivic2eg's Avatar
Default m/t 22x8x15s what tire pressure should i go with?
on mt slicks trying to figure out what is the best psi to run with at the track... did a search but nothing... and what rpms should you lauch at? (on stock axles) thanks
Old Apr 15, 2004 | 02:50 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: m/t 22x8x15s what tire pressure should i go with? (jdmekcivic)
u prolly dont want stock axles what i am wonder the same Q
Old Apr 15, 2004 | 03:03 PM
94gsr4dr's Avatar
Default Re: m/t 22x8x15s what tire pressure should i go with? (CrxStreetRacer)
for the time being i run those slicks, but i run about 13-14 pounds. I need bigger slicks, but you will need to feather the clutch to keep those axles in good shape.
Old Apr 15, 2004 | 03:16 PM
1 2 NV's Avatar
i ran mine at 8-8.5 for best results, launching at 8k
Old Apr 15, 2004 | 04:33 PM
gsrmattski
Guest
Posts: n/a
Default Re: m/t 22x8x15s what tire pressure should i go with? (1 2 NV)
1 2 NV what are your 60fts like?
Old Apr 15, 2004 | 07:25 PM
1 2 NV's Avatar
Default Re: m/t 22x8x15s what tire pressure should i go with? (gsrmattski)
as a street car launchin alot more conservatively at 7k i was only gettin 1.8s. for the last 2 yrs ive been gettin 1.7s and upper 1.6s on my MTs as a racecar. but i launch alot higher.
92redhatch
Mar 27, 2009 08:03 PM
1994PreludeSi
Jul 21, 2007 05:19 AM
b16-bomber
Mar 13, 2006 11:41 AM
LSVTEC 91 Civic
Apr 2, 2005 07:17 PM
98civicEX
May 20, 2002 10:56 PM
