Zeal b2s and having alignment problems.
anyone have the zeal B2s and having trouble with alignment. I raised the car all the way up and went to just tires to get an alignment and the guy couldn't put the passenger side to spec. the negative camber was out of spec range. The guy told me that I need to get a camber kit to put it into spec. Is it the pillow mounts that threw off my camber. The steering wheel is slightly to the right to go straight but not bad. Also, when I adjust the height according to measuring the threads on the coil bodies, the passenger side is almost 1/8 inch lower. Anyone experience the same problems??? Any suggestions. could there be something else wrong?
chewtext
Suspension & Brakes
Sep 15, 2005 08:59 AM
