Will ITR caliper bolt up to a DA Kuckle/hub??
Old Apr 15, 2004 | 08:08 AM
DB8's Avatar
DB8
Default Will ITR caliper bolt up to a DA Kuckle/hub??
as topic said, just picked up a EF with DA front brake, so i am thinking of upgrading it with a set of ITR front caliper, anyone done this swap before?
i know for a fact that i will need the 93-96 prelude vtec rotor redrill to 4x100, anything else needed?
thanks in advance
Old Apr 15, 2004 | 09:49 AM
1's Avatar
Default Re: Will ITR caliper bolt up to a DA Kuckle/hub?? (DB8)
search is your friend
Old Apr 16, 2004 | 08:32 AM
DB8's Avatar
DB8
Default Re: Will ITR caliper bolt up to a DA Kuckle/hub?? (1)
just did, but no luck, most of the post are for DC integra instead of the DA hub/kuckle i am referring to, if anyone have any info on it, please post
Thanks in advance
Old Apr 16, 2004 | 08:41 AM
4drEF's Avatar
Keyboard Humorist
The 91-94 Accord Wagon front calipers are THE SAME CALIPER as comes on the TypeR. EXACTLY THE SAME. The caliper bolts onto the EX knuckle and everything fits fine. The EX knuckle uses the same caliper as the DA.
Old Apr 16, 2004 | 08:58 AM
onePOINTsix's Avatar
Default Re: Will ITR caliper bolt up to a DA Kuckle/hub?? (4drEF)
awsome i was wondering this myself
Old Apr 16, 2004 | 09:53 AM
cursED's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">The 91-94 Accord Wagon front calipers are THE SAME CALIPER as comes on the TypeR. EXACTLY THE SAME. </TD></TR></TABLE>
You can even use the ITR pads (for the track, etc.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">The caliper bolts onto the EX knuckle and everything fits fine...</TD></TR></TABLE>
You should shave the caliper bracket for proper alignment (sorry, I don't have the link or measurements at work).
huge230
Oct 12, 2007 07:49 PM
JDMThoughts
12
Feb 10, 2005 02:42 PM
CRX Toad
13
Jan 19, 2005 08:06 AM
thehatchninja
Feb 17, 2003 02:00 PM
