shaking, vibrating during idle.
My car is shaking and vibrating consistently during idle. It is a 92ex manual w/ 137k. I had the timing belt done at 84k. I am also only getting 20-21mpg. Any ideas if these problems are related?
thanks.
thanks.
If its a rough idle,
I would:
run some bg44k fuel cleaner through
check spark plugs/wires
dizzy
air filter
If the idle persists then I would lean towards rear motor mount
Your low MPG could be related to a inefficient fuel system or an o2 sensor going out or clogged cat.
GL abd hope this helps.
I would:
dizzy
air filter
.Your low MPG could be related to a inefficient fuel system or an o2 sensor going out or clogged cat.
civikhatch91
Sep 7, 2008 07:50 AM
twisted civic
Jul 17, 2008 08:08 PM
