Attn: People running test pipes
Old Oct 29, 2001 | 08:37 AM
HX_Guy's Avatar
Default Attn: People running test pipes
For those of you who run a test pipe...does your car "stink" like gas/exhaust fumes while idling?
Mine smells very strong...and Im not sure if its because of the test pipe utself, an exhaust leak..or maybe running way too rich at idle (due to the cams).
Old Oct 29, 2001 | 08:44 AM
Chris's Avatar
Default Re: Attn: People running test pipes (HX_Guy)
I think it could be all three.. all contributing to the "smell".
Old Oct 29, 2001 | 08:48 AM
Muglit's Avatar
New User
Default Re: Attn: People running test pipes (Chris)
I smell the fumes when I park and get out of the car, but not when I am in the car.
Old Oct 29, 2001 | 08:52 AM
HX_Guy's Avatar
Default Re: Attn: People running test pipes (Muglit)
Blah...mine kills me!!!
It used to be so bad that my eyes got sore while at stop lights! And my clothes stink like gas after a 20 minute drive
Ive leaned it out alot at idle and it has helped some...but still stinks horribly.
Ill have to check for leaks...maybe play with the fuel @ idle some more..and if all else fails..Ill have to get a cat.
Old Oct 29, 2001 | 09:26 AM
b20b's Avatar
New User
It shouldn't stink up inside your car, if so, your probably running to rich. Because there is less filtering, yes you will smell the gas more, however if it is coming in the cabin, that sounds more like a exhaust leak. Try lookin towards the front, usually for the smell to be that pertinent in the cabin, it should be in the front. The exhaust will come through the vents.
By the way, be careful if your car is smelling like gas that much. Carbon monoxide is very dangerous, and will put you unconscious very quickly. Drive with the windows open.
Old Oct 29, 2001 | 10:06 AM
kickdown's Avatar
That sounds really scary. I wouldnt be cruising something like that. You need to get that fixed asap =]
kickdown
. . quote . .
Old Oct 29, 2001 | 10:33 AM
FAST94GSR's Avatar
New User
Default Re: Attn: People running test pipes (kickdown)
you'll smell it when you get out of the car for sure, if you smell it while your driving inside the cabin you got a leak. That's kinda dangerous, you could pass out, not too mention its pretty unhealthy.
Old Oct 29, 2001 | 10:34 AM
HX_Guy's Avatar
Default Re: Attn: People running test pipes (FAST94GSR)
I dont smell it while actually driving...just while idling.
Old Oct 29, 2001 | 01:20 PM
PM-Performance's Avatar
what do you think the purpose of a catalyti converter is?????
answer that and youll find the answer to your question
Old Oct 29, 2001 | 01:38 PM
HX_Guy's Avatar
Default Re: Attn: People running test pipes (itr206)
Good point
Old Oct 29, 2001 | 02:00 PM
BoM's Avatar
BoM
do u still have carpeting and seats? when i drove around gutted...it was loud and smelly everywhere!
Old Oct 29, 2001 | 02:10 PM
HX_Guy's Avatar
Default Re: Attn: People running test pipes (bommiE)
Yep...full carpet and tar underneath.
Old Oct 29, 2001 | 02:47 PM
PureTeg420's Avatar
I don't smell anything different unless i get out of the car and go to the trunk while it's still running. My vote goes for exhaust leak.
Old Oct 29, 2001 | 04:45 PM
Erik_Pb_Foot's Avatar
New User
Default Re: Attn: People running test pipes (PureTeg420)
Is there an open bung on your testpipe? If so, BINGO! Gotta seal it up... I know someone that forgot to seal theirs, not good. You would probably hear that though.... I'd guess you have a combination of a small exhaust leak (check all seals and gaskets, especially around test pipe) and the fact that you have no CAT would account for the rest. Good luck.
Old Oct 29, 2001 | 04:50 PM
owen_the_soyboy's Avatar
mine does smell a bit after long times at idle, kind of sweet smelling I guess.
but not enough for anyone to ever say... "do you run a testpipe?"
not as bad as my old racecar.. a 1980 ford fiesta with a straight tubed exhaust, no cat.. that thing smelled like sulfur and gas fumes, it was heinous!!!
Old Oct 29, 2001 | 07:17 PM
Grandprix's Avatar
Default Re: Attn: People running test pipes (owen_the_soyboy)
my friend has a GSR with JDM header, test pipe and exhaust, and can never smell anything out of the ordinary. Of course there is carbon on the rear bumper after a few week. Smells just fine though. Actually...I put my face up to the exhaust as the car was idling...hehehe...couldnt smell anything at all.
My old Pontiac...man that thing stank like hell WITH the cat.
Old Oct 30, 2001 | 12:22 PM
Default Re: Attn: People running test pipes (Grandprix)
HEY EVERYONE . . . IM TRYING TO GET A TEST PIPE MADE NOW, DOES ANYONE HAVE ALL THE DIMENSIONS I OUWLD NEED, , ,, LENGTH, DIAMETER DISTANCE BETWEEN THE HOLES IN THE FLANGES ETC, PLEASE LET ME KNWO ASAP. THANKS.
blue_egsi
Apr 18, 2012 03:38 PM
DOHCon15s
Dec 19, 2003 02:34 PM
khcivic
Feb 11, 2003 06:37 PM
HX_Guy
Oct 29, 2001 10:10 AM
HX_Guy
Sep 8, 2001 09:59 AM
