Differences from 88-91 Civic hatchbacks (Si specifically)
Old Oct 29, 2001 | 08:19 AM
Todd00's Avatar
I said I don't want a title!
Default Differences from 88-91 Civic hatchbacks (Si specifically)
I'm wondering what Honda changed from the 89 to the 91 Civic Si. Things like side door impact beams, weight items, engine tweaks, etc. Is there a webpage that lists something like this?
Thanks.
Old Oct 29, 2001 | 11:55 AM
89civicdx's Avatar
Default Re: Differences from 88-91 Civic hatchbacks (Todd00)
This is what I know about Canadian models
88 civ/crx has the jdm style rear lower control arms(diff shock as well)
90-91 crx/civ have a different flywheel/clutch assembly, the clutch disk hub uses springs instead of bushings,IMO those disks are garbage if you look at them the wrong way the springs rip out
The 90-91 civ/crx has diff front brakes, the part#'s are diff(check Hawk cat for this) ,the brakes are no bigger in dia but the thickness and pad monting tabs are diff(I think)
there is no 88 si civ(not in Canada)
slight changes for the wiring harness for 90-91 crx/civ
Front bumper is diff from 89 civ-90/91 civ
civ front corner lenses are diff from 89-90/91 civ
civ front bumper lip is diff from 89-90/91
civ rear taillights are diff from 89-90/91
Old Oct 29, 2001 | 07:25 PM
Todd00's Avatar
Default Re: Differences from 88-91 Civic hatchbacks (89civicdx)
Thanks for the reply.
Anyone know how much more the 91 weighs than the 89?
Old Oct 29, 2001 | 07:28 PM
HyperREV's Avatar
New User
i think the 90-91 Si's have a slightly stronger cam as well.
Old Oct 29, 2001 | 10:03 PM
CLICC916's Avatar
well, my stock 90 civic si with full interior and about 1/2 a tank of gas weighed about 2380 lbs...i dunno how much the 89's weigh, but i'm sure they weigh less (couple pounds here and there maybe)
Old Oct 30, 2001 | 01:46 PM
RaCnLeGenD's Avatar
Default Re: Differences from 88-91 Civic hatchbacks (CLICC916)
the 91s look ALOT nicer....wider.....MEANER...thats just my opinion.....
Old Oct 30, 2001 | 02:00 PM
SiR Kid's Avatar
New User
I'm glad I'm not the only one with an OBESE 91 SI.... Damn thing weighed 2350 with out rear seats, spare or jack...
No wonder the B16a struggled n/a in my li'l porker...
Old Oct 30, 2001 | 04:00 PM
CLICC916's Avatar
Default Re: Differences from 88-91 Civic hatchbacks (SiR Kid)
oh yeah, that weight was with my 2 8-in. subs and box in the back as well...i never run gutted, but if i did i'd figure my weight would be sleightly below the 2300 lb range...sad....my b16 struggles too, my best time has only been 15.1@92.6 mph. oh well...nothing some ctr's can't fix
Old Oct 30, 2001 | 05:29 PM
eg6ajk's Avatar
'88
Exterior Dimensions CRX CRX HF CRX Si DX hatchback Hatchback Weight - Manual (lb.) 1922 1819 2011 1993 1933
'89
Manual (lb.) 2048 1834 2138
Exterior Dimensions DX hatchback Hatchback Si Hatchback
Weight - Manual (lb.) 2088 2013 2161
'91
Manual (lb.) 2103 1967 2174
Exterior Dimensions DX hatchback Si Hatchback Standard Hatchback
Manual (lb.) 2165 2291 2127
dylaxiin
Nov 10, 2011 07:43 PM
daluv
21
Dec 3, 2008 04:43 PM
ineedacrx
Oct 7, 2005 10:16 AM
effinnwackk
Aug 26, 2004 12:26 AM
BdoubleU
Nov 22, 2002 11:44 PM
