ITR/GSR Front Sway Bar Installation onto GS....does it fit without modifications???
the ITR rear sway definately needs fabrication to be installed onto any other 3G integra....so i've come to the conclusion to invest in the comptech rear tie bar/22mm sway bar combination kit.....but the front sway bar needs to be swapped out of my GS to that of a GSR/ITR sway to have the same setup as the ITR.....(24mm Front, 22mm Rear).....
Question????
Does the Front GSR/ITR Sway Bar go on to my GS without any fabrication??
Question????
The GS-R/Type-R front swaybar will bolt-on to your GS.
FYI, in addition to the GS-R/Type-R (24mm) front swaybar, you will also need GS-R/Type-R endlinks and swaybar bushings. To install the swaybar you will need to disconnect the exhaust and the shift linkage, since the swaybar is mounted above these two components.
navin
Oct 29, 2002 05:04 PM
