How to identify a genuine JDM ITR by looking at the suspension?
Old Apr 14, 2004 | 09:51 PM
marko_think's Avatar
Default true jdm itr?
by looking at the suspension, how do you know if its a true jdm itr?
Old Apr 14, 2004 | 09:58 PM
esponet's Avatar
jdm 5 lugs has bigger axle nuts. other than that its the same chiet
Old Apr 15, 2004 | 02:00 AM
mugenracer's Avatar
96-98 had 4 lug 4x114.3, theres not much to tell it apart from other JDM integras, the shocks will be Showa and part numbers are:
Rear- 52610-ST7-Z010 (96-0215)
Front- 51602-ST7-Z010 ( 96-0214 -Right)
>>>>>>>>>>>>&g t;>>> (96-0216 - left)
These are the part numbers of my 96Spec JDM ITR and so will probably be different for 98Spec suspension.
Old Apr 15, 2004 | 08:54 AM
owen_the_soyboy's Avatar
Default Re: (esponet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet &raquo;</TD></TR><TR><TD CLASS="quote">jdm 5 lugs has bigger axle nuts. </TD></TR></TABLE> you mean 98+ specifically.
Old Apr 15, 2004 | 09:30 AM
Jon D's Avatar
Default Re: (mugenracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">96-98 had 4 lug 4x114.3, theres not much to tell it apart from other JDM integras, the shocks will be Showa and part numbers are:
&gt;&gt;&gt;&gt;&gt;&gt;&gt;&gt;&gt;&gt;&gt;&gt;&g t;&gt;&gt;&gt; (96-0216 - left)
These are the part numbers of my 96Spec JDM ITR and so will probably be different for 98Spec suspension.</TD></TR></TABLE>
You mean 96-97 have the 4-lug 4x114.3....98 started the five-lug
Old Apr 15, 2004 | 10:17 AM
esponet's Avatar
yes 96spec itrs have 4x114, brake size is the same as gsr.
98 spec itrs have 5x114. same as usdm but the axle nut ,outer cv joints,bearing and hubs are bigger.
usdm 5 lugs are based of ctr susp.
Old Apr 15, 2004 | 10:26 PM
is it true there are more spot welds on the jdm itr then gsr or usdm itr's?
is the jdm itr suppose to have a bar welded to the frame, near the rear lower control arms?
Old Apr 15, 2004 | 10:29 PM
92TypeR's Avatar
FSAE
Default Re: (marko_think)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marko_think &raquo;</TD></TR><TR><TD CLASS="quote">is it true there are more spot welds on the jdm itr then gsr or usdm itr's?
is the jdm itr suppose to have a bar welded to the frame, near the rear lower control arms?</TD></TR></TABLE>
Chassis and suspension is identical between USDM and JDM ITR's. 98 spec has 1mm larger rear swaybar.
Old Apr 16, 2004 | 04:42 AM
DB8ITR's Avatar
Default Re: (B18C-Rsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C-Rsi &raquo;</TD></TR><TR><TD CLASS="quote">
You mean 96-97 have the 4-lug 4x114.3....98 started the five-lug </TD></TR></TABLE>
Actually its 95.5 - 97 with the 4 lug. They swapped front ends mid year and started making the ITR's.
Old Apr 16, 2004 | 05:24 AM
Jon D's Avatar
Default Re: (R #189)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R #189 &raquo;</TD></TR><TR><TD CLASS="quote">
Actually its 95.5 - 97 with the 4 lug. They swapped front ends mid year and started making the ITR's.</TD></TR></TABLE>
I thought that it was that the 96s were introduced in September of 95 and thats why some say 95.5 .
Old Apr 16, 2004 | 10:35 AM
Chris N's Avatar
Default Re: (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">
98 spec has 1mm larger rear swaybar.</TD></TR></TABLE>
and front.
24/22 USDM
25/23 JDM
Old Apr 16, 2004 | 12:47 PM
kepani's Avatar
Default Re: (Chris N)
how about the rear control arm? aren't the usdm ones stamped steel versus the jdm cast steel?
kepani
Old Apr 16, 2004 | 03:32 PM
niall1's Avatar
My JDM ITR is a '98 but has 4 lug hubs??
Old Apr 16, 2004 | 04:19 PM
ITRbroham's Avatar
shit post warrior
Default Re: (niall1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by niall1 &raquo;</TD></TR><TR><TD CLASS="quote">My JDM ITR is a '98 but has 4 lug hubs??</TD></TR></TABLE>
Huh?
Old Apr 16, 2004 | 04:52 PM
^jefs0ng's Avatar
Banned
The early/first 98s I believe had 4 lug. The mid/later ones had 5.. right?
Old Apr 17, 2004 | 04:20 PM
Default Re: (^jefs0ng)
mine is 5 lug '00 is the year
Old Apr 17, 2004 | 04:36 PM
niall1's Avatar
As it's an import I only have the year of registration, so I guess it's an early one. I understand there was a no cost option 'race spec' with soundproofing/airbags/radio/digi clock/ABS/rear wipe/rear brake light deletion. That's my spec with a black interior and a slightly different rear bumper to the UK/US ITR
Old Apr 18, 2004 | 05:53 AM
Default Re: (kepani)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kepani &raquo;</TD></TR><TR><TD CLASS="quote">how about the rear control arm? aren't the usdm ones stamped steel versus the jdm cast steel?
kepani</TD></TR></TABLE>dont think so.
Old Apr 19, 2004 | 07:29 AM
esponet's Avatar
alot of them replaced the 5 lug with 4x114 for racing. (lighter)
Old Apr 19, 2004 | 07:53 AM
JDMITR222's Avatar
Default Re: (owen_the_soyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by owen_the_soyboy &raquo;</TD></TR><TR><TD CLASS="quote">dont think so.</TD></TR></TABLE>
Yes the rear upper control arm on the usdm is justs a flat piece of steel.Where as the JDM is tubular so it's a bit more stronger.
Old Apr 19, 2004 | 07:58 AM
Default Re: (JDMITR222)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMITR222 &raquo;</TD></TR><TR><TD CLASS="quote">
Yes the rear upper control arm on the usdm is justs a flat piece of steel.Where as the JDM is tubular so it's a bit more stronger. </TD></TR></TABLE> oh yeah, the UPPER one, good catch....
Old Apr 19, 2004 | 10:20 AM
JDMITR222's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by owen_the_soyboy &raquo;</TD></TR><TR><TD CLASS="quote"> oh yeah, the UPPER one, good catch.... </TD></TR></TABLE>
No prob
Old Apr 26, 2004 | 11:07 AM
since jdm and usdm itr's is mostly indentical to eachother. how can you tell if they did a rhd conversion on a usdm itr? or...or
if it was a rhd gsr and they converted it to a itr spec. what are some of the things that cannot be converted? because it would take too much time and cost too much. like the soundproofing crap.
Old Apr 26, 2004 | 02:34 PM
mugenracer's Avatar
USDM and JDM ITRs are far from being identical to each other.....completely different fronts, battery on the right hand side on JDM cars, master cylinder on opposite sides....
Old May 12, 2004 | 09:21 PM
ok new question...what are some of the things someone cannot convert to make it an itr if it was a gs-r?
