NEED ASAP! B20 into EG swap question!
Old Apr 14, 2004 | 07:28 PM
Glen Tennis's Avatar
Default NEED ASAP! B20 into EG swap question!
What mount do I need for the drivers side? I used a civic DX mount. All the other mounts line up fine but the driver's one is about an inch too high and there is no way in hell we can coax it to fit. What mount do I need to use?
BTW - its a 2001 B20 into a 92 EG.
Old Apr 15, 2004 | 12:23 AM
Default Re: NEED ASAP! B20 into EG swap question! (Rockinfunzone)
just real quick like ok?
Old Apr 15, 2004 | 12:38 AM
Maintenance's Avatar
Which rear bracket did you use? Try using the ls mount for the driverside. That's how I did mine when i had the swap.
Old Apr 15, 2004 | 08:47 AM
VTECVillain's Avatar
You need to use a 94-01 Integra driver's side mount bracket and mount.
Old Apr 15, 2004 | 12:10 PM
I'm using the integra rear bracket.
So you are saying I need to reaplace the B20 mount bracket with an intrgra one? Replace it with a GSR mount or an LS?
Old Apr 15, 2004 | 12:12 PM
JDM EJ1 95's Avatar
im pretty sure its an LS... it seems like it will work fine
Old Apr 15, 2004 | 07:08 PM
jsdxhatch's Avatar
Default Re: (JDM EJ1 95)
all integra mounts are the same, so use a gsr one, ls one, w/e u can get ur hands on
Old Apr 15, 2004 | 07:34 PM
Rickety's Avatar
Default Re: (jsdxhatch)
"Naturally Aspirated Dreams" in ur info... word on the street is those cars have absolutely insane cars! I cant wait till i get a hold of a copy
Old Apr 15, 2004 | 09:42 PM
You say that the LS and GSR are the same so use either one? I know that the GSR one has three holes and they are lined up, the bracket on the B20 has only two holes and they are at a slant so I cant use the GSR one.
Old Apr 16, 2004 | 05:08 AM
Default Re: (Rockinfunzone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rockinfunzone &raquo;</TD></TR><TR><TD CLASS="quote">You say that the LS and GSR are the same so use either one? I know that the GSR one has three holes and they are lined up, the bracket on the B20 has only two holes and they are at a slant so I cant use the GSR one.</TD></TR></TABLE>
Yes the LS, GSR and even the ITR all have the same driver's side bracket and mount. The 94-01 Integra's are all the same. The reason that you can't use the GSR mount is because you are trying to put it on the CRV bracket. You MUST change the bracket to a 94-01 Integra as well. Just like I said before, use a 94-01 Integra bracket AND mount and it will bolt right in.
Old Apr 16, 2004 | 09:55 AM
Default Re: (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">
Yes the LS, GSR and even the ITR all have the same driver's side bracket and mount. The 94-01 Integra's are all the same. The reason that you can't use the GSR mount is because you are trying to put it on the CRV bracket. You MUST change the bracket to a 94-01 Integra as well. Just like I said before, use a 94-01 Integra bracket AND mount and it will bolt right in.</TD></TR></TABLE>
Ok now its clear, thanks for the info vtecvillain!
Old Apr 21, 2004 | 02:04 PM
Ok I found my problem. Someone who had the motor before I did put a weird *** bracket on the drivers side. It sticks out more and is about an inch higher than the LS or GSR bracket. So I eventually used a GSR bracket and mount and the motor is in the car. People were saying I was crazy and that it should work but I showed this bracket around and no one knows what car is came from.
Recyclingfreak
May 6, 2017 08:27 PM
924doorEG
Dec 2, 2011 07:34 AM
mustang5.slow
14
May 26, 2007 11:22 PM
b20ek
Jun 28, 2003 12:40 PM
4g4me
Jul 25, 2002 01:38 PM
