OBD2b itr ecu in 99 civic. Have coded key and swapped pins. Still doesn't work
Old Apr 14, 2004 | 04:43 PM
sinatra's Avatar
Default OBD2b itr ecu in 99 civic. Have coded key and swapped pins. Still doesn't work
Is there something I am missing here? I have the key with the code in it for this ECU. I swapped the pins for the fuel pump as per Katman's directions. It should start but, alas, no go. Anyone know what I could do to remedy it short of removing the immobilizer or going on a killing spree at my local supermarket?
Old Apr 14, 2004 | 05:44 PM
sinatra's Avatar
Default Re: OBD2b itr ecu in 99 civic. Have coded key and swapped pins. Still doesn't work (1993sir)
Not aware of that please elaborate.
Old Apr 16, 2004 | 12:24 AM
sinatra's Avatar
Default Re: OBD2b itr ecu in 99 civic. Have coded key and swapped pins. Still doesn't work (sinatra)
Glad to see people check the hybrid section often.
Old Apr 16, 2004 | 05:24 AM
Mr Boston's Avatar
I think your best choice is to remove the immbolizer. Do you have the ignition from the integra? You would need to swap over the ignition,etc.. from the ITR for that coded key to work in your 99 civic. The immbolizer system consists of the ecu,coded key,and the ignition. This is what I know from my knowledge so I could be wrong.
Old Apr 16, 2004 | 07:11 AM
TurboBumblBee's Avatar
Default Re: OBD2b itr ecu in 99 civic. Have coded key and swapped pins. Still doesn't work (Clicky Pow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Clicky Pow &raquo;</TD></TR><TR><TD CLASS="quote">I think your best choice is to remove the immbolizer. Do you have the ignition from the integra? You would need to swap over the ignition,etc.. from the ITR for that coded key to work in your 99 civic. The immbolizer system consists of the ecu,coded key,and the ignition. This is what I know from my knowledge so I could be wrong.</TD></TR></TABLE>
correct.. your 99 Civic does not have an immobilzer built into the key cynlinder right now.. yes you have the key w/ the code, but nothing to send the code to the ecu to start the car.. best bet in your situation would be to remove the immobilizer from the ecu
Old Apr 16, 2004 | 08:22 AM
sinatra's Avatar
Default Re: OBD2b itr ecu in 99 civic. Have coded key and swapped pins. Still doesn't work (Boostfedb18c1)
Thanx guys. Removed the immobilizer from one of the ECUs. Works great when the car finally starts. Any ideas on why it take s awhile to start?
speedminded
Oct 25, 2004 10:52 AM
shadykit
May 20, 2004 11:44 AM
PYITR821
Apr 23, 2004 04:23 AM
mugen-man
Jul 10, 2003 12:08 PM
