Brake dust shields
does anyone remove them....I'm contemplating it...and was weighing the pros and cons
I think I will since I upgraded to poly ball joint boots(anyone ever use those?)
I was worried before that my balljoints would be seeing too much heat from the rotors so I left them on
I took mine off and covered the b00tz (tie rod and ball joints) and ABS wire in reflective tape from pegasus.
http://pegasusautoracing.com/pdfs/088.pdf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">I took mine off and covered the b00tz (tie rod and ball joints) and ABS wire in reflective tape from pegasus.
http://pegasusautoracing.com/pdfs/088.pdf</TD></TR></TABLE>
I pulled mine off, didn't cover anything with anything, and melted my lower boots. Go figure. They were 16 years old, so who knows if there's a connection, but when I replace them I'm going to cover them this time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">I took mine off and covered the b00tz (tie rod and ball joints) and ABS wire in reflective tape from pegasus.</TD></TR></TABLE>
do u have actual pics of this ??
yea, I took mine off and didn't cover them up yet but thanks for the heads up. I am also worried that grease could come out of either the axel or the lower ball joint and get on rotors or mess up pads. As anyone had trouble with that. I have those shitty Energy Suspension lower ball joint cups which don't really lock onto anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCracer723 »</TD></TR><TR><TD CLASS="quote">do u have actual pics of this ??</TD></TR></TABLE>
Nope.
Nope.
Yeah, hookit up .RJ.
***Edit: nevermind
***Edit: nevermind
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D.CACO »</TD></TR><TR><TD CLASS="quote">Yeah, hookit up .RJ.
https://honda-tech.com/zerothread?id=258996
Willard's pics. Same idea.
</TD></TR></TABLE>https://honda-tech.com/zerothread?id=258996
Bill Hook
Sep 17, 2003 08:34 AM
