type s ecu hondatafied in ep3
Old Apr 14, 2004 | 12:38 PM
JoeyBallzSI's Avatar
Default type s ecu hondatafied in ep3
Here's the deal. I'm planning on using the type s ecu with the hondata k series programmable. I have a 2003 si and I plan on doing a motor/tranny swap. K24 block type s head and type s tranny. With all that said will this ecu set up work with my cars stock controls (windows and all other features of the car) or does it not matter?
Old Apr 14, 2004 | 12:41 PM
DC5ITR329's Avatar
Default Re: type s ecu hondatafied in ep3 (JoeyBallzSI)
the ecu only control the motors function. There are different relays and brains for the windows and locks etc...
Old Apr 14, 2004 | 01:18 PM
DaMasteR's Avatar
New User
Personally I think you'd go for the K20. It's less heavy and easier to get more power out.
Just a thought.
Old Apr 14, 2004 | 05:35 PM
Default Re: type s ecu hondatafied in ep3 (DaMasteR)
Thanks I didn't know that. Not felling higher compression motor will be turboed and I'm def. felling the benefits of lots more torque and displacement plus the fact that the set up is going to be rare.
Old Apr 14, 2004 | 11:11 PM
DaMasteR's Avatar
New User
I think any K20/K24 swap into an si would be rather rare I don't think there were done any in Europe. What about over there?
The K20 engine has much more power potention. We are about to swap one into an ITR and see if we manage to get it set at around 260HP, n/a.
Old Apr 15, 2004 | 05:34 AM
B18CXr's Avatar
see sig
Old Apr 15, 2004 | 06:10 PM
SiRocket02's Avatar
Default Re: type s ecu hondatafied in ep3 (B18CXr)
so, what am i lookin to spend on parts if i decided i wanted to build a k24 frankenstein...just a rough estimate would be fine
Old Apr 15, 2004 | 06:21 PM
DC5ITR329's Avatar
Default Re: type s ecu hondatafied in ep3 (SiRocket02)
I wouldn't build a K24 frankinstein. For reliablility reasons. I know that there are some good builders but there is nothing more reliable then stock. If I were you and want to go turbo then I would get a Type S motor and turbo it. If you were going all motor then I would go K20a. This is my opinion though.
Old Apr 16, 2004 | 08:10 PM
Default Re: type s ecu hondatafied in ep3 (aznbo1626)
Type s motor turbo stock isn't that great. Compression is to high to boost a lot. **** what mister honda built. My question for everybody is how come when you ask a question on honda tech you get the run around and everyones opinion when you are even asking it. i asked a simple question about an ecu and look what I got.
moe.
Mar 10, 2008 01:12 PM
skata89
Mar 12, 2006 08:21 AM
gsr_to_the_MAX
Feb 3, 2005 02:17 PM
jaycuzz1
Jun 19, 2004 04:23 AM
legendj
Acura TL, RL & ZDX
Jan 8, 2004 08:14 PM
