Question for those with Skunk2 Exhaust on DC5
Old Apr 14, 2004 | 10:59 AM
LiL DeViL's Avatar
Default Question for those with Skunk2 Exhaust on DC5
have you experienced any leaks where the exhaust bolts up to the cat? if so what gasket did you use to fix it? i used the gaskets that came with the exhaust but they started leaking and the bolts were tight. i tried replacing them with gaskets by Mr. Gasket (header collector gaskets) but there is still a leak. i went and got a factpry gasket from acura and it wont stay in place. the guy at acura told me it was a "smash gasket" whatever that means, and they wont put it on for me cause i have an aftermarket exhaust. can someone please help a girl out.
Old Apr 14, 2004 | 12:33 PM
dwnshft02's Avatar
Default Re: Question for those with Skunk2 Exhaust on DC5 (NUrDrmz)
I've never had any problem with mine and it's been on for about a year and a half. First make sure thats where it's leaking. If your positive thats where it's coming from I'd contact Skunk2 and try to get the gasket they provide and replace it. The other one you had may have just been a bad one.
Old Apr 14, 2004 | 03:47 PM
LiL DeViL's Avatar
Default Re: Question for those with Skunk2 Exhaust on DC5 (dwnshft02)
would a copper gasket fix it? i know the header collector gaskets by Mr. Gasket are not metal, but thought a metal one might work. THanks.
Old Apr 15, 2004 | 05:46 PM
Davanca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NUrDrmz &raquo;</TD></TR><TR><TD CLASS="quote">would a copper gasket fix it? i know the header collector gaskets by Mr. Gasket are not metal, but thought a metal one might work. THanks.</TD></TR></TABLE>
I would contact skunk2 and let them know about the problem. Most likely they will send you a new gasket for free. As for me i had the exhaust for about 5 months, i haven't experienced any problems like that. A copper gasket might fix the prob, but why spend money if you can possibly get it for free.
Old Apr 15, 2004 | 07:01 PM
ROCcityRSX_S's Avatar
im gunna guess it might just be a defect from skunk2, i dont have that problem at all
Old Apr 16, 2004 | 07:26 PM
LiL DeViL's Avatar
Default Re: (ROCcityRSX_S)
actually i am starting to think i have the same problem a friend had with the same exhaust on a different car. there is a possibility that the flange where it connects to the cat has a slight warp in it. going to take it off the car and check it out with a level, then contact Skunk2 AGAIN cause they have never wrote me back about the gasket.
tekstyle
Oct 22, 2009 06:54 PM
OrangeTeggy
May 29, 2009 07:31 AM
lando griffin
Jan 15, 2009 03:51 PM
jonnybadboi9
May 8, 2008 06:16 PM
