How often should you replace your fluids in your Integra?
How often do you need to replace all the fluids in your integra?
Powersteering, clutch, brake, transmission, radiator, etc.?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline07 »</TD></TR><TR><TD CLASS="quote">How often do you need to replace all the fluids in your integra?
Powersteering, clutch, brake, transmission, radiator, etc.?</TD></TR></TABLE>
Powersteering: I change the fluid every 2-3 years. ( I use the "turkeybaster" method, and just change the fluid in the reservoir)
Radiator: Every 2 years
Brake fluid: Every 2 years
Oil: Every 5 k miles. I had a UOA done on my oil at 5K miles and the analysis showed that my oil was fine.
