rear camber kit
Old Apr 14, 2004 | 09:17 AM
willywonka's Avatar
Default rear camber kit
what is a good one to buy thats not expansive ? thanks
Old Apr 14, 2004 | 09:22 AM
.bagged's Avatar
Default Re: rear camber kit (willywonka)
https://honda-tech.com/zerothread?id=677097
https://honda-tech.com/zerothread?id=619347
https://honda-tech.com/zerothread?id=462372
https://honda-tech.com/zerothread?id=433853
That should give you a start..
or you could just washer it up if its not too bad..
Old Apr 14, 2004 | 10:04 AM
willywonka's Avatar
Default Re: rear camber kit (baGged93aCcord)
how do u do the washer thing im going to go with that
Old Apr 14, 2004 | 10:09 AM
.bagged's Avatar
You can space out the rear upper control arm from the inner fender well with washers which will correct the camber slightly
Old Apr 14, 2004 | 08:26 PM
willywonka's Avatar
how much camber can u change and will it squeak ?
Old Apr 14, 2004 | 08:29 PM
.bagged's Avatar
NOt sure about the exact degree of correction but if you have a ton of camber you might just want to get a kit..It wont squeek as long as you tighten it right.
Old Apr 15, 2004 | 07:13 AM
willywonka's Avatar
ok this is how low it is what do u think ?
i donno if u can see form it that well but if it helps
Old Apr 15, 2004 | 08:08 AM
SearchBeforeUPost!'s Avatar
You can still use the washer trick in the back, get a longer bolt if needed.
Old Apr 15, 2004 | 09:07 AM
.bagged's Avatar
Default Re: rear camber kit (SearchBeforeUPost!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SearchBeforeUPost! &raquo;</TD></TR><TR><TD CLASS="quote">You can still use the washer trick in the back, get a longer bolt if needed. </TD></TR></TABLE>
I agree..and try to get a pic from the top angle of the back wheel
Old Apr 15, 2004 | 11:03 AM
willywonka's Avatar
ok will do .. im just out of town ... but when i get back i will do it .. i might even do a right up on it ?
Old Apr 15, 2004 | 11:25 AM
.bagged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willywonka &raquo;</TD></TR><TR><TD CLASS="quote">ok will do .. im just out of town ... but when i get back i will do it .. i might even do a right up on it ?</TD></TR></TABLE>
Definately and then we can add it to the Basic Guide.. Great Idea!!
bartek_b
Oct 7, 2003 04:45 PM
projectM
Mar 11, 2003 03:01 PM
91_hatch_si
Dec 30, 2002 09:15 PM
Denny
Dec 15, 2002 07:22 PM
HBack94cx
Jul 25, 2002 08:50 PM
