BUMPED THE LIMITER IN 5TH GEAR!!!!!!!!!!!!
well i finally really maxed out R#667, it actually hit the rev limiter in 5th gear, anyone know what speed that is???
thanks
later
thanks
later
where did you do a top speed run at? The Garden State Parkway?? You're lucky a trooper didn't get ya. Probably would have thrown your *** in jail and impounded your car. Keep it off the public roads man, that's what tracks were designed for.
You're gonna kill somebody, if not yourself.
why didn't you look at your speedo?
tj
how long a straight do you need to hit ~150s?
That would probably calculate to 159 but that isn't accounting for drag which would probably slow the car to the 140 range.
BS ........
You need over 210+ whp to get to the fuel cut off in an R (8,600).
Stock R's do 143, and you picked up over 15 mph in top speed from minimal mods??
People always seem to have no concept of aerodynamics and wind resistance when they talk about top speed driving.
Where's the pic Lip had of him doing about 158?? And he didn't tach it out, and had over 190 whp .......
Regarding the drag issue:
if the tachometer is correct, the conversion using the gear ratio and wheel size to linear speed will ALWAYS be accurate.
There is drag acting, but there is no correction to be performed on the speed value obtained from the RPM reading.
How hard was it pulling up to redline?
I just hit 140 last week! It was ******* awesome! Car felt stable, and was still pulling really strong. Nothing like being in 5th gear when vtec kicks in!
You should do it again and get it on video.
GOD DAMN PHOTOPOINT.... I gotta host my images elsewhere...
Click Here For Speedo Picture
[Modified by skafia, 7:58 AM 10/29/2001]
3rd gear
I've had it between the N and L of Only in Unleaded only...but for some reason i can't find that photo
no idea why they aren't coming up
