compression to high or no?
Old Oct 28, 2001 | 08:26 PM
tsjag17's Avatar
New User
Default compression to high or no?
i have a gsr with stock pistons with a gsr head shaved 30 thou is that compression to high to run a 18g turbo kit pushin 6 psi? till i get my new head in or what?
Old Oct 29, 2001 | 04:20 AM
BoM's Avatar
BoM
Default Re: compression to high or no? (tsjag17)
.30thousands is about .3-.5 points right?
soo ur at about type R compression
run the highest octane available, be careful of running the greddy kit,
even though its pretty safe. i don't trust the blue box.
i dont' liike milling heads, you should've gotten another headgasket or sumthing, later
you might run into problems if your going all out.
goodluck
[Modified by bommiE, 8:24 AM 10/29/2001]
Old Oct 29, 2001 | 04:46 AM
89civicdx's Avatar
Default Re: compression to high or no? (bommiE)
Nothing wrong with milling your head, but now you got to make sure your timing is correct because the milling retards your timing so get a timing light with an advance and get a set of cam gears.
BUT I have no idea about running high comp and a turbo.
Old Oct 29, 2001 | 07:13 AM
rainforest's Avatar
Default Re: compression to high or no? (89civicdx)
if i were you I would trade your head to someone for a stock head. hahahahahahah
Old Oct 29, 2001 | 03:56 PM
tsjag17's Avatar
New User
Default Re: compression to high or no? (rainforest)
i am trading head next week but till then u think it would be cool to run 6.5 psi on my car with the head milled 30thou. my new head is a gsr head portflow valve springs and retainers and itr outer valve springs. itr cams aem cam gears
Old Oct 29, 2001 | 05:24 PM
rioninja's Avatar
If your trading heads, then just get a thick headgasket (a good one) to lower things a bit. But again, your gonna need adjustable camgears.
Old Oct 30, 2001 | 06:24 AM
tsjag17's Avatar
New User
Default Re: compression to high or no? (RioNinja)
i have aem cam gears and itr cams
slammedem1
Jan 21, 2009 06:08 PM
candy eg
Jun 28, 2006 01:38 PM
McFly
Mar 29, 2003 12:38 PM
Peter K
Jul 1, 2002 05:14 PM
DYI01
Mar 9, 2002 02:40 PM
