Big problems ! ! ! ! !
Old Apr 14, 2004 | 03:05 AM
Rickcrx's Avatar
Default Big problems ! ! ! ! !
Well id just change the clutch and flywheel and axles.The thing is when it was time to start the car the car was dead.We checked all the grounds and we try another battery.Also when we were puchin the car i had it on gear and i dumped clutch and the car didnt do anything.I know if u dump the clutch at least the car would hold but this time it didnt.So can somebody tell me what to do?Thax
Rick
Old Apr 14, 2004 | 04:37 AM
TheHatchHog's Avatar
Default Re: Big problems ! ! ! ! ! (Rickcrx)
Transmission ground, main relay , blown fuse? Check all your fuses, also what motor ? Is your starter cranking over at all?
Old Apr 14, 2004 | 06:08 AM
Rickcrx's Avatar
Default Re: Big problems ! ! ! ! ! (civicciviccivic)
D16a6.The starter doesnt do anything.
Old Apr 18, 2004 | 08:41 PM
jump the starter . + and - from battery. It should crank over. if not bad starter. it should make a clicking sound.
Old Apr 18, 2004 | 08:47 PM
TomO's Avatar
did you make sure that the spade connector was attatched on the Starter itself? that is the signal the ECU uses to actually crank the car over.
ogshokka
Nov 8, 2010 09:46 AM
Yeah Daybid
Apr 3, 2009 01:42 PM
EK k kay
Jun 19, 2006 10:25 PM
s2kkid
Feb 13, 2005 03:16 PM
itrSteez
Dec 4, 2002 06:05 PM
