spun rod bearing ??
Old Apr 13, 2004 | 07:21 PM
hksbigboi4's Avatar
Default spun rod bearing ??
what is a spun rod bearing and how do i fix it. (b16)
Old Apr 13, 2004 | 07:49 PM
krazie1's Avatar
BANNED
Default Re: spun rod bearing ?? (hksbigboi4)
do u hear something knocking in the block when u start it if u can even do that
and if u got that I recommend u having the crank checked out
and well new bearings of course silly
Old Apr 14, 2004 | 07:15 PM
hksbigboi4's Avatar
alright well my friend GAVE ME a b16 block cuz he just wanted to get rid of it.. and he told me there was a spun rod bearing.. i just want to know how to fix it so i can start building on the block..thanks
Modified by hksbigboi4 at 4:09 AM 4/21/2004
Old Apr 14, 2004 | 07:22 PM
IMALLSLO's Avatar
Pull the pan.....splash shield.....and rod caps. Inspect the crank and bearing. Should be aluminum color with no abnormal wear. A spun bearing looks like someone took a blowtorch to it and will be rough and grooved. In the pan you will also find bearing/metal materials. If this is the case,the crank will have to be removed and polished and all bearings and the damaged rod will have to be replaced. In some cases it ruins the crank completely and winds up being more costly then buying a good runing block. Think about how many spare b16 crank and rods are lying around? This usually occurs from lack of oil pressure to the crank from debris or a bad oil pump or 500 thousand miles without an oil change.
Old Apr 16, 2004 | 01:20 AM
hksbigboi4's Avatar
Default Re: spun rod bearing ?? (IMALLSLO)
i pulled the pan today and thats what i saw.. actually its exactly what i saw.. thanks.. sik ride too
Old Apr 16, 2004 | 07:38 AM
IMALLSLO's Avatar
No problem....pull the crank and have it miked(sp?) to tell whether its reusable.....if not you just bought yourself alot of spare aluminum.
Old Apr 16, 2004 | 07:47 AM
1990civicsiguye's Avatar
you also should know that when replacing the rod bearing you need to get the right color...... i will guess you are new to building motors .... because you dont know how to do it..... so you need the set of numbers of the back of the block the ummm tranny side they will be like BCBCC or somthing ....... that is what my zc is that is why i used that example .... then you need the numbers from the crank in the order you find them...... ie.... 2323..somthing like that opps left one out ohhh welll then go to honda and tell um you need the bearings they will color code your bearings .... that is there sizing thing ..... ie black blue pink green ... there is some more ...hopfully that will help a little ....
Old Apr 16, 2004 | 07:48 AM
the ones for the rods are on the rods i didnt put that on there sorry.... right on the caps themselvs......
hardcore97
Apr 23, 2015 07:55 PM
soon2bdropped
Dec 14, 2010 03:42 PM
USDM-EK4*
16
Jul 11, 2009 06:05 PM
ziggy3784
Apr 30, 2009 07:48 AM
SuckMyDOHC
Jun 15, 2008 11:29 AM
