How To: Si swaybar on your civic.
Old Apr 13, 2004 | 06:42 PM
silverb18's Avatar
Default How To: Si swaybar on your civic.
I recently installed a civic si swaybar on my 6th gen civic ex. Needless to say, it made my car handle so much better. For all of you out there without a sway bar, this is an easy and affordable way to go. The link below has directions on how to do it, enjoy.
http://www.hazone.com/hsirearsway.htm
Old Apr 13, 2004 | 06:44 PM
JDMlyfestyle's Avatar
Good shiet man. nice write up
Old Apr 13, 2004 | 06:48 PM
soundbomber's Avatar
Default Re: How To: Si swaybar on your civic. (silverb18)
ahh for the rear, good write up
Old Apr 13, 2004 | 06:52 PM
GetawayInMoscow's Avatar
Default Re: (JDMlifestyle)
How big is the SI sway bar?
How does it compare to the LS and GSR sway bars?
Old Apr 13, 2004 | 06:57 PM
piscorpio's Avatar
Default Re: (GetawayinMoscow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayinMoscow &raquo;</TD></TR><TR><TD CLASS="quote">How big is the SI sway bar?
If memory serves, the Si bar is 13mm. Not sure about the LS/GS-R.
Old Apr 13, 2004 | 07:26 PM
silverb18's Avatar
Default Re: (piscorpio)
The Si sway bar is 13mm, so is the LS. The gsr bar is 14mm, the type r is 22mm. The only one that directly bolts up to the 6th gen is the si sway bar. If you want to get a thicker rear sway bar on your civic, like the gsr or type r, i would suggust getting a thicker one for the front too because the type r rear sway bar is much thicker than the stock civic front sway bar.
Old Apr 13, 2004 | 07:50 PM
ruthless013's Avatar
i was so hoping this was for the front sway bar.
the rear should be a purely bolt-on affair, no brainer.
nice effort though.
Old Apr 14, 2004 | 06:30 PM
piscorpio's Avatar
Default Re: (silverb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverb18 &raquo;</TD></TR><TR><TD CLASS="quote">The Si sway bar is 13mm, so is the LS. The gsr bar is 14mm, the type r is 22mm. The only one that directly bolts up to the 6th gen is the si sway bar. If you want to get a thicker rear sway bar on your civic, like the gsr or type r, i would suggust getting a thicker one for the front too because the type r rear sway bar is much thicker than the stock civic front sway bar.</TD></TR></TABLE>
It isn't essential though. I am running a 19mm rear bar and 0 front sway bar on my VX, and it does not feel unsafe or dangerously oversteer. Now whether the front bar might balance out the handling and improve it overall, I can not say.
Old Apr 14, 2004 | 07:25 PM
AzCivic1.6's Avatar
did you steal my avatar? i've never seen anyone else have it in the last 3 years.
Old Apr 14, 2004 | 07:30 PM
greenf1's Avatar
Default Re: (AzCivic1.6)
best upgrade you can do
Old Apr 14, 2004 | 08:09 PM
Kidnkorner's Avatar
Default Re: (greenf1)
i thought u had to have the lower control arms. i have a 00 hatch.
Old Apr 14, 2004 | 08:14 PM
Default Re: (Huggy Bear)
nope, not for 96-00 civics. we all got lca's with holes for endlinks
Old Apr 14, 2004 | 10:12 PM
silverb18's Avatar
Default Re: (soundbomber)
indeed
Old Apr 22, 2004 | 02:09 PM
slowcivic'00's Avatar
im a noob, i just wanted some input on why getting a swaybar off of an SI would be better as opposed to buying one aftermarket? price? handling? or what? If choosing the SI bar because of price, if price wasn't an issue, would aftermarket necessarily be better?
Old Apr 22, 2004 | 09:07 PM
REDGEAR's Avatar
Can the Si sway work with aftermarket LCA's? To be more specific the SPC LCAs
Old Apr 22, 2004 | 09:29 PM
silverb18's Avatar
Default Re: How To: Si swaybar on your civic. (REDGEAR)
it depends on what you want, for me, the Si sway bar is enough, i don't road race, i'm mostly going for 1/4 mile. You can always get a thicker sway bar, but the Si ones are pretty cheap and if you do get a thicker rear than the Si, you should probably upgrade the front sway bar as well.
Old Apr 22, 2004 | 09:46 PM
EricUSC's Avatar
The Si rear swaybar is a good upgrade for a Civic EX. I have one myself. Just be sure you torque it to factory specs.
Old Apr 22, 2004 | 10:05 PM
rMak's Avatar
Default Re: How To: Si swaybar on your civic. (EricUSC)
its cheap, and easy to come by if you wait a bit on the classifieds. most people that have moved up to comptech and itr and whatnot have an si bar laying around. i got mine with endlinks for 55 shipped. pretty cheap upgrade. i hear that you dont really feel it unless your other suspension is upgraded as well
Old Apr 22, 2004 | 11:39 PM
STREETWERKZ's Avatar
Default Re: How To: Si swaybar on your civic. (slowEJ8)
i have an EG sedan. any front or rear sway bars for my car?
my friend gave me his 2002 civic SI stock bars, but im 99% they aint gonna work, theyre just gonna sit in my garage.
Old Apr 23, 2004 | 12:04 AM
Mr. Choi's Avatar
New User
Default Re: How To: Si swaybar on your civic. (STREETWERKZ)
need one for the front? i got a nice kit that will help you guys out, check my sig.
italian_virus
Jun 25, 2010 09:11 PM
SoullessJapaneseMachine
Suspension & Brakes
Oct 10, 2007 07:43 PM
PARADOX_sf
Suspension & Brakes
19
Jan 10, 2007 01:40 PM
99civic_exSB
Jul 7, 2003 05:17 PM
NTGR8D
Mar 13, 2003 11:13 PM
