**help**crower cam question for people who have them
Old Apr 13, 2004 | 04:32 PM
6thgen_H22accord's Avatar
Default **help**crower cam question for people who have them
Has anyone put these on their car h22 motor and had put crower roller rockers? I had them installed on the car and vtec would not engage it would almost shut off like there was a rev limiter. The shop who did the work called crower and they told him i need the roller rockers, i wana know has anyone else who has them needed to install new crower roller rockers?
Old Apr 13, 2004 | 04:54 PM
98 blacksh's Avatar
Default Re: **help**crower cam question for people who have them (6thgen_H22accord)
what stage are your cams, i have heard that you need to grind down the rockers on some cams cant remember which ones but that could be the problem
Old Apr 13, 2004 | 05:31 PM
well i ordered the stage 2's and now that im looking at the box the part number is for the stage 3's
Old Apr 13, 2004 | 07:04 PM
CBR's Avatar
CBR
Anything beyond Crower Stage 2 cams, you will need to modify your rocker arms. Follow my link to my previous post regarding this issue.
I hope you didn't do much damage to your valve spring retainers/rocker arms, since you already ran the engine.
Good luck.
https://honda-tech.com/zerothread?id=593951
Old Apr 13, 2004 | 07:20 PM
i hope i diddnt since i just had all new valvetrain installed.
Old Apr 13, 2004 | 07:59 PM
NXLude's Avatar
I had to grind every last rocker arm to get clearance with my 2s.....
Old Apr 13, 2004 | 09:46 PM
Eddiebx's Avatar
if ur gonna get roller rockers, then you wont have vtec, cuz the only roller rockers i've seen for the h22 are vtec eliminators
Old Apr 13, 2004 | 09:58 PM
VTECRaZeR's Avatar
Default Re: (NXLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NXLude &raquo;</TD></TR><TR><TD CLASS="quote">I had to grind every last rocker arm to get clearance with my 2s.....</TD></TR></TABLE>
I know this question is about the crower cams....but I'm wondering if all the aftermarket cams will make you do the same thing, like skunk2?
I been thinking about getting a whole valvetrain so I kinda want to know what I'll have to do to get them to work and without eliminating VTEC like (Eddiebx) said.....
Old Apr 14, 2004 | 04:02 AM
ok well how hard was it to gring down the rockers? Im gona have to do this i guess and I dont wana eliminate my vtec, thanks guys I wish i had this info before they were installed
Old Apr 14, 2004 | 05:19 AM
thehondaguru's Avatar
wow that sucks I hope that my **** doesnt get screwed up now because I have the 2's and Ididdnt even think about grinding down the rockerarms
Old Apr 14, 2004 | 06:07 AM
94vtecmn's Avatar
Default Re: (95 lude)
Mine were all ground to clear as well.
Old Apr 14, 2004 | 06:48 AM
are yours running fine and does your vtec engage without problems? If it does i dont see no need why you would have to worry, im worried cause i cant even engage so im sure mine are a must in order for mine to work correctly
Old Apr 14, 2004 | 01:16 PM
Default Re: (6thgen_H22accord)
I dont know if vtec works yet because my vss is bad so it doesnt engage
Old Apr 14, 2004 | 01:33 PM
well i found out that crower sent me stage 3 cams, the lobe was so big it waas hitting the spring not the retainers no damage was done to the springs though
Old Apr 14, 2004 | 01:39 PM
woah, your cams are not suposed to hit your springs or retainers. I think you misunderstood yourself
bertsb18hatch
Apr 15, 2007 04:21 PM
preludeguy_92
Jul 12, 2005 05:28 PM
codeh22a4
14
Dec 9, 2004 04:32 PM
gaydm.accord
Jun 9, 2004 06:48 AM
