idle really bad
Hey friends i have a small question my accord 97 is idling like from .5 to 2 rpms everytime i run mine car to high rpms like 6 rpms, but if i drived it normal it won't do that. i already changed the tps sensor and it is still doing it. do you know what else could it be, may be you had this problem before. i tryed with another map sensor and is still doing it. so i put the old one back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburner247 »</TD></TR><TR><TD CLASS="quote">Uh, I'm guessing that you're trying to say that you have a really low idle.
Have you tried looking for an "idle adjustment screw"?</TD></TR></TABLE>
sounds more like a fluctuating idle you know? iu dont remember which sensor, but when my friend and i were checkin out his hatchs engine after installing it and started it up it would idle from around 500 to 2000 the whole time without stopping... and the culprit was a sensor on the intake manifold. like iatb or something like that.... someone will know and chime in sooner or later...
