Nitrous on an R?
Old Oct 28, 2001 | 04:35 PM
HokieITR's Avatar
New User
Default Nitrous on an R?
Anyone done this? I've done turbo on an LS before but never really looked into Nitrous. I assume you have most of the same concerns, fuel, timing, etc. Can anyone comment on how safe this is though, etc?
Old Oct 28, 2001 | 04:36 PM
VT-ITR1's Avatar
New User
Default Re: Nitrous on an R? (HokieITR)
how big of a shot are you looking at? (btw where are you at, i go to VT also, probably met you already, im the R with the white racing hart wheels)
Old Oct 28, 2001 | 04:38 PM
Type-ARR's Avatar
Default Re: Nitrous on an R? (00 ITR 506)
Jimmy.......bad idea.........you want "TURBO"......say it with me "TURBO"
-Josh
Old Oct 28, 2001 | 04:41 PM
hybrid_eg's Avatar
here is what i would do:
first get your ECU done, you need a jumper and a chipped ECU.
Get something like a spoon header w/test pipe and exhaust
set of cam gears, FPR, vtec controller, a step up colder plugs i.e. 7
intake, get it tuned and run like 40-50 shot dry.. it should give you good 200whp+ easily. btw, dont forget to get a clutch installed too.
Old Oct 28, 2001 | 04:46 PM
HokieITR's Avatar
New User
Default Re: Nitrous on an R? (hybrid_eg)
Well, right now I have AEM CAI, DC Sports JDM 4-1, Carsound highflow, and DC Sports cat back. I think the previous owner did a 75 dry shot with a fuel pump, and plugs... I'm told it was enough to go mid 12's.
Old Oct 28, 2001 | 04:48 PM
HokieITR's Avatar
New User
Default Re: Nitrous on an R? (ITR-481)
Hah... I have to probe all the possibilities!
-Josh
Old Oct 28, 2001 | 05:34 PM
hybrid_eg's Avatar
75 is really pushing it! i would never go over 50hp.. most likely 40..
just get a few good bolt ons, too keep the car reliable and still be more responsive over stock, then just have that 40-50 shot in case you need to prove yourself to someone. heheheeh
so basically you have a car that feel much stronger then stock everyday on the street, then you can laugh at the v8's when you feel like it
Old Oct 28, 2001 | 05:38 PM
chad's Avatar
Moderator
nos is the cheap way.,.....but turbo is cheaper in the long run depending how often you use the bottlE
si0385.
Jan 29, 2007 05:34 PM
Greenery18
Jul 27, 2004 09:33 PM
integra2ner
Jan 6, 2003 09:54 PM
36Chambers
Mar 31, 2002 10:17 PM
DaNish
Oct 18, 2001 05:40 PM
