installing new door panels ??
Old Apr 13, 2004 | 02:22 PM
SPOONup's Avatar
Default installing new door panels ??
can anyone tell me the general process ... do i need to take the door panel of as a whole? im just installing type r panels on my ls ... just the insert piece , not the whole door piece. thanks
Old Apr 13, 2004 | 02:27 PM
Audi A4's Avatar
Default Re: installing new door panels ?? (showcaseinteg)
you will have to take the whole thing off.
Old Apr 13, 2004 | 02:28 PM
SPOONup's Avatar
Default Re: installing new door panels ?? (DRAG lll INTEGRA)
haha any other advice please ?????????????
Old Apr 13, 2004 | 02:30 PM
JDMjames's Avatar
you have to take the whole door panel off.
Old Apr 13, 2004 | 02:31 PM
ubreak_ubuy's Avatar
u have to remove the whole door panel
SPOONup's Avatar
Default Re: installing new door panels ?? (JDMjames)
yes i apreciate the comment but looking for a lil more detail .. maybe ill take it off and see its no biggy ... sorry
Old Apr 13, 2004 | 02:32 PM
Audi A4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by showcaseinteg &raquo;</TD></TR><TR><TD CLASS="quote">haha any other advice please ????????????? </TD></TR></TABLE>
no thats all there is to it, u have to take the whole thing off... its easy.... 3 screws and then pull on it at the bottom... just clips after u take the screws out.. take 2 mins to take one off
Old Apr 13, 2004 | 02:33 PM
SPOONup's Avatar
thanks man
Old Apr 13, 2004 | 02:35 PM
Audi A4's Avatar
more detailed.
1. take the screw out at the change holder thingy..aka the cup u use to close ur door form the inside
2. take the screw out where the indide door handle is... get a flat head to undo the little flap...
3. take the screw out on actuall door panel... its more of a palstic screw( be carefull not to mess it up)
4 tug on the bottom part... its clipped on so just give it some power.
then it should all come off in one big peice..
Default Re: (showcaseinteg)
not sure how u install inserts when the door panel is one whole piece. i would like to know how its done
Old Apr 13, 2004 | 07:45 PM
SPOONup's Avatar
Default Re: (raceinspired)
k i took the whole door panel off ... all i need to do is to take out the atual samll insert of carpet material ... if u look behind the whole door panel its all one piece .. does this insert not come out ???? when u guy talk about getting new door panel for ls and rs do u get the whole new door panel or just replace the inserts ??? im confused thanks
Old Apr 13, 2004 | 07:56 PM
SPOONup's Avatar
help anyone ????
Old Apr 13, 2004 | 07:58 PM
Kendall's Avatar
The insert isn't removable. You'll need to just peel the carpet off and then replace it with whatever you deem necessary.
Old Apr 13, 2004 | 08:00 PM
SPOONup's Avatar
Default Re: (Kendall)
i was afraid u would say that .. thanks tho
lshatch916
Jun 24, 2007 06:03 PM
Si_Prelude
Dec 12, 2005 06:32 AM
CWBETB
12
Jul 1, 2005 07:18 AM
lude97dude
Jan 17, 2004 08:23 AM
SoCar
Nov 18, 2003 01:37 PM
