WTF???
Old Apr 13, 2004 | 03:10 PM
StolenTeg's Avatar
Default WTF???
So i was installing my new bronze 15x7 rota and when i was tighting the bolt, One of the stick on the passenger side where i was tighting the lug nut break. So i only have 3 tighting on the passenger side now. Is there any way i can fixed this myself of i have to go to a shop and get it done? approx. how much would it cost???
Old Apr 13, 2004 | 03:21 PM
Audi A4's Avatar
Default Re: WTF??? (StolenTeg)
u can replace it ur self...and the stick is really called a stud
Old Apr 13, 2004 | 03:22 PM
Russ713's Avatar
dAng!
They really don't cost much at all. Suggestion is to let the shop do it for you if you are not familiar with those parts. You'll probably spend between 20 - 40 bux.
Old Apr 13, 2004 | 05:34 PM
StolenTeg's Avatar
Would it be bad or damage something if i drive around with it like that???
Old Apr 13, 2004 | 05:42 PM
nickgmiller04's Avatar
3/4 lugs is not safe. i work in a wheel/tire shop and replace studs all the time. go to a shop if youre not familar w/ the replacement, which youre probably not since you broke the stud. no offense.
drive directly to the shop if its close. id drive as little as possible till you get that fixed.
also, make sure to get a new lug for the new stud.
another tip: hand tighten all the lugs evenly before using a lug wrench. if one feels like its going on wrong, dont force it. take it off, and start again. or youll break studs, or strip studs or lugs.
torque your lugs to 80 lb/ft
just trying to help w/ some of the small knowlege i have
Old Apr 13, 2004 | 08:14 PM
vman's Avatar
Just remove the hub w/an impact and punch out the old stud and replace w/a new one(I have never changed one on a teg but pretty sure it is the same)
Good luck
EJ8CIVIC
Texas -OK -LA (Sales)
13
Sep 27, 2013 04:21 AM
BobbyRodriguez
Apr 27, 2011 05:06 PM
eLUDEnu
Welding / Fabrication
32
Sep 17, 2004 12:58 PM
vtec_lude
Jun 19, 2004 02:21 PM
detour6931
Jul 27, 2001 11:40 AM
