H22 Swap But I wanna go turbo, Should I Sleeve H23 block or sleeve H22?
Old Apr 13, 2004 | 12:49 PM
acaccord04's Avatar
Default H22 Swap But I wanna go turbo, Should I Sleeve H23 block or sleeve H22?
Im gonna do a H22 Swap but I want turbo where i can run a good amount of boost and I keep wondering if an H23 block is goin to hold up better than an H22 or is it the same and should I sleeve both, and my next question is How much boost have you ever seen run safely like this?
Old Apr 13, 2004 | 01:20 PM
H23vtecEG's Avatar
Default Re: H22 Swap But I wanna go turbo, Should I Sleeve H23 block or sleeve H22? (acaccord04)
same blocks
Old Apr 13, 2004 | 06:11 PM
acaccord04's Avatar
Default Re: H22 Swap But I wanna go turbo, Should I Sleeve H23 block or sleeve H22? (H23vtecEG)
so what are you sayin, the H23 block is basically a h22 block bored so it has thinner cylinder walls?Please tell me something
Old Apr 13, 2004 | 07:03 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acaccord04 &raquo;</TD></TR><TR><TD CLASS="quote">so what are you sayin, the H23 block is basically a h22 block bored so it has thinner cylinder walls?Please tell me something</TD></TR></TABLE>
They are pretty much the same (aka casting)
Old Apr 14, 2004 | 08:31 AM
H23vtecEG's Avatar
Default Re: H22 Swap But I wanna go turbo, Should I Sleeve H23 block or sleeve H22? (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">
They are pretty much the same (aka casting)</TD></TR></TABLE>
meaning only the internals like crank,rods, and pistons arent the same. the blocks are identical.
Old Apr 14, 2004 | 11:18 AM
Nick H's Avatar
New User
the sleeves are made of different materials as well, but both motors have the same bore...it's the h23's use of the f22 crank that gives it the longer stroke, creating the 2.3 liters of displacement...
Old Apr 14, 2004 | 06:55 PM
acaccord04's Avatar
Default Re: H22 Swap But I wanna go turbo, Should I Sleeve H23 block or sleeve H22? (Nick H)
Would I just be wasting my money goin h23 block or should I just get an h22 and sleeve it 4 turbo?
blkknight619
Aug 8, 2005 10:32 AM
deca
Apr 6, 2005 04:39 AM
BLUE EH3
Apr 8, 2004 11:16 AM
2.2SICKLUDE
Aug 29, 2003 03:46 PM
