Aftermarket Intake Manifolds for SOHC?
Old Apr 13, 2004 | 11:20 AM
trooper0641's Avatar
Default Aftermarket Intake Manifolds for SOHC?
I have a d15b w/ bolt ons... i/h/e...which aftermarket IM would be best for my setup? Is the skunk2 any good? Could i match the IM w/ a bigger throttle like an LS's or would i have to bore it out?
Old Apr 13, 2004 | 11:21 AM
Ricey McRicerton's Avatar
Default Re: Aftermarket Intake Manifolds for SOHC? (trooper0641)
Spade knows all about this.
He was in love with one of them, but I can't remember wether it was the Edlebrock or the Skunk2. I want to say it was the Edlebrock.
Old Apr 13, 2004 | 11:24 AM
bad93ex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote">I have a d15b w/ bolt ons... i/h/e...which aftermarket IM would be best for my setup? Is the skunk2 any good? Could i match the IM w/ a bigger throttle like an LS's or would i have to bore it out?</TD></TR></TABLE>
When I had my SOHC it was to my knowledge that you could only gain about 2~3 whp with an IM.
Old Apr 13, 2004 | 11:25 AM
skip.two's Avatar
i thought it was Skunk2. where's Spade?
Default Re: Aftermarket Intake Manifolds for SOHC? (bad93ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad93ex &raquo;</TD></TR><TR><TD CLASS="quote">
When I had my SOHC it was to my knowledge that you could only gain about 2~3 whp with an IM.</TD></TR></TABLE>
Spade dyno tested at more than double that I do believe.
Old Apr 13, 2004 | 11:26 AM
that aint bad
bad93ex's Avatar
Default Re: Aftermarket Intake Manifolds for SOHC? (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
Spade dyno tested at more than double that I do believe.</TD></TR></TABLE>
Really? Double what?
Old Apr 13, 2004 | 11:27 AM
Br1anPham's Avatar
Interesting topic. I heard good things about Sunk2 IM for sohcs (and dohcs).
Old Apr 13, 2004 | 11:28 AM
skip.two's Avatar
doubled whp than your guess of 2-3whp
Old Apr 13, 2004 | 11:29 AM
bad93ex's Avatar
Default Re: Aftermarket Intake Manifolds for SOHC? (jL iLLuZiOnz 9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 &raquo;</TD></TR><TR><TD CLASS="quote">doubled whp than your guess of 2-3whp</TD></TR></TABLE>
I suppose that is not that bad then.
Old Apr 13, 2004 | 11:34 AM
If i get the Edelbrock IM for my sohc...would i have to port the intake manifold to match the LS's 60mm? How big is the sohc Edelbrock IM anyways?
Old Apr 13, 2004 | 11:39 AM
kommon_sense's Avatar
spade had the edelbrock and got around 6whp gains on a stock d16y8 with just bolt-ons.
edelbrock IM has a 62mm opening.
7thGear's Avatar
read this
https://honda-tech.com/zerothread?id=653889
enjoy
Old Apr 13, 2004 | 11:41 AM
Default Re: Aftermarket Intake Manifolds for SOHC? (7thGear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7thGear &raquo;</TD></TR><TR><TD CLASS="quote">read this
enjoy </TD></TR></TABLE>
You're a good good man!
Old Apr 13, 2004 | 11:44 AM
JDMs1eeper's Avatar
The PerformerX Was 5whp over the y8 manifold , untuned.
The Skunk2 made the same as the y8 & 2-3whp after extra fuel was added.
Old Apr 13, 2004 | 11:45 AM
bad93ex's Avatar
You're a good good man!</TD></TR></TABLE>
Good link.
I was right with my guesses.
Old Apr 13, 2004 | 11:46 AM
JDMs1eeper's Avatar
dang on, lol this is moving fast
Old Apr 13, 2004 | 11:49 AM
Default Re: Aftermarket Intake Manifolds for SOHC? (kommon_sense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kommon_sense &raquo;</TD></TR><TR><TD CLASS="quote">spade had the edelbrock and got around 6whp gains on a stock d16y8 with just bolt-ons.
edelbrock IM has a 62mm opening.</TD></TR></TABLE>
dam 62mm!? how am i suppose to match that?
Old Apr 13, 2004 | 11:52 AM
dam 62mm!? how am i suppose to match that? </TD></TR></TABLE>
Isn't the ITR TB a 62mm peice?
Old Apr 13, 2004 | 11:56 AM
7thGear's Avatar
, i for one learned the value of the search button a long time ago....
Old Apr 13, 2004 | 11:59 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote">dam 62mm!? how am i suppose to match that? </TD></TR></TABLE>
You don't really have to worry about matching, you just don't want the TB to be larger than the IM opening.
Old Apr 13, 2004 | 12:00 PM
7thGear's Avatar
unless you custom fab and make the IM opening larger...
id do it... but i dont know how to weld
Old Apr 13, 2004 | 12:02 PM
Civic_95_Si's Avatar
I'm pretty sure the ITR is 62mm, but I bought a 62mm from BBK.
Old Apr 13, 2004 | 12:03 PM
Default Re: Aftermarket Intake Manifolds for SOHC? (Civic_95_Si)
wow 62mm type r throttle body...how much is that going to cost me? a leg?.... or 2?
Old Apr 13, 2004 | 12:10 PM
how much do the PerformerXs go for anyways? where could i find one for a great price?
