turbo or na??? im confuse...
Old Apr 13, 2004 | 10:21 AM
ironchef25's Avatar
Default turbo or na??? im confuse...
i dont know how should i go about. b16 is running good. looking for not a fast car but something that i can be proud of.. now if i go turbo i know im getting good hp maybe atleast 13 sec but im worried about the reliablity. ive also read here on ht that na cars are better and faster than a turbo.. na is cheaper and turbo is expensive.. for turbo im looking at maybe a custom turbo maybe spent somewhere around 3500 where i can build a na car p&p, valve jobs,type r cams, gears,pistons, rods and chipped ecu for like 3000. and maybe that setup will take me atleast 13. thats not including a bottle kit for like 700. man im so confuse im not looking for a big hp gain just enough to hit 13's i h ave a 88crxhf b16.. please help me out guys. guide me.. shed me some light to the right path......
Old Apr 13, 2004 | 10:35 AM
kid-honda's Avatar
O boy here comes the idiots.
Everything in a idiots hands in unreliable.
Do what you want.
Both are just as reliable as the other if built properly.
Old Apr 13, 2004 | 10:41 AM
sporkcrx's Avatar
Default Re: (kid-honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">O boy here comes the idiots.
Do what you want.
Both are just as reliable as the other if built properly.</TD></TR></TABLE>
Well said. On that note turbo's are better This shouldn't even be a question
Old Apr 13, 2004 | 10:42 AM
ironchef25's Avatar
well ive heard that turbo has more chances of ruinning your engine than na.. now that could not always be the case. some of you guys will say that depends on the person using it.im not the kinna person who races and has a lead foot.but yah somewhat reliable.. and easy to maintain..and has the capability of hitting 13 high low dont matter to me as long as it hits it. lol.
Old Apr 13, 2004 | 10:45 AM
ironchef25's Avatar
Default Re: (ironchef25)
also ive read somewhere here in ht. not sure when but it said something like
spend the same amount on a car turboing it and spend the same amount on a na car.. na will mostly own the turbo car.. not sure if this is true though..
Old Apr 13, 2004 | 10:52 AM
sporkcrx's Avatar
drive some stupid na car
then drive a turbo car
you'll see the light
Old Apr 13, 2004 | 11:10 AM
y49crxsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironchef25 &raquo;</TD></TR><TR><TD CLASS="quote">also ive read somewhere here in ht. not sure when but it said something like
spend the same amount on a car turboing it and spend the same amount on a na car.. na will mostly own the turbo car.. not sure if this is true though.. </TD></TR></TABLE>
Thats exactly opposite. It is ussually much cheaper to build a turbo car, over an NA car, for the same hp goals. For 2000 grand, you could have one badass turbo setup, using turboedit, or some ecu program, for tuning, and run 12's all day long on a stock b16a. As long as it is tuned right, the b16 can handle upwards of 300 hp at the wheels. TO reach your goal of 13's, it might actually be cheaper to do it NA, but it might not. SOme aggressive cams, with valtrain alone will cost about a grand, maybe a little less, then some decent headwork, will cost around 800 or so, and then some tuning, and your already over 2000, and only running 13's, mid to high 13's too. Boost has so much more potential, and is soooo fun.
Oh, and i built my turbo setup for around 1000 bucks, using a vafc2 and 450cc dsm injectors for feul. This setup is good for up to 11psi.
Old Apr 13, 2004 | 11:35 AM
ironchef25's Avatar
Default Re: (y49crxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y49crxsi &raquo;</TD></TR><TR><TD CLASS="quote">
Oh, and i built my turbo setup for around 1000 bucks, using a vafc2 and 450cc dsm injectors for feul. This setup is good for up to 11psi. </TD></TR></TABLE>
how did you do that??
Old Apr 13, 2004 | 11:44 AM
StupidSlowRSX's Avatar
Do what you want.
Exactly, If you have the money, I have the knowledge.
Old Apr 13, 2004 | 11:46 AM
bardo's Avatar
Default Re: turbo or na??? im confuse... (ironchef25)
&lt;---------turbo b16 crx
Old Apr 13, 2004 | 11:54 AM
CHRIS 1.8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironchef25 &raquo;</TD></TR><TR><TD CLASS="quote">well ive heard that turbo has more chances of ruinning your engine than na.. now that could not always be the case. some of you guys will say that depends on the person using it.im not the kinna person who races and has a lead foot.but yah somewhat reliable.. and easy to maintain..and has the capability of hitting 13 high low dont matter to me as long as it hits it. lol. </TD></TR></TABLE>
That is not true.
A turbo motor and a NA motor BOTH have equal chances of being ruined. Lack of fuel, lack of tuning, and lack of maintenance can cause both types of motors to decrease its life.
Lets just say that if a turbo motor and a NA motor were both properly tuned and there were no problems. A turbo motor may be more reliable because you do not have have to rev as high as a NA motor to make power and puts less stress on the motor.
Remember: RPM = Ruins Peoples Motors
The higher you rev to make power, the more stress your motor undergoes.
Example: NA motors
Old Apr 13, 2004 | 12:02 PM
onePOINTsix's Avatar
Default Re: (CHRIS 1.8)
bahh just go turbo, for some cheep badass turbo setups goto http://www.homemadeturbo.com
Old Apr 13, 2004 | 12:06 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (Sideout)
Turbo= $$ for power
NA=$$$$$ for power
Tubro best bang for the buck, although with a b16 you might want swap the internals for ls or ITR compresson, or you could always slap a b20 block on the B16 head
Old Apr 13, 2004 | 12:21 PM
beavis's Avatar
its all about how your car is tuned
Old Apr 13, 2004 | 12:25 PM
ironchef25's Avatar
Default Re: turbo or na??? im confuse... (ZCed89hatch)
can i slap a turbo on a stock internals b16? motor has about 45000 miles.
maybe boos like only 5 psi to 7
Old Apr 13, 2004 | 12:39 PM
xci_ed6's Avatar
Default Re: (sporkcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">drive some stupid na car
you'll see the light </TD></TR></TABLE>
werd muthafucka
boost has no equal
Old Apr 13, 2004 | 12:47 PM
SOHCEK-Turbo's Avatar
Do what you want.
Agreed get a good engine management such as Hondata and your engine will be just as reliable. There is many on here with Turbo making nice power with stock internals. But they do have engine management.
Modified by SOHCV-TechRider at 10:04 PM 4/13/2004
Old Apr 13, 2004 | 12:49 PM
Mrfirefox's Avatar
Well said. On that note turbo's are better This shouldn't even be a question </TD></TR></TABLE>
Turbo is faster and usually cost less for the power
so yea it's never really a question in my mind
If you wanna go NA get a hemi, or another big V-8
Old Apr 13, 2004 | 01:01 PM
5litereater's Avatar
Default Re: (Mrfirefox)
in order to get the power you want out of na you're definaTELY gonna need some crazy cams. this isnt all that great for daily driven cars. personally i think a turbo is better for your daily driver ( boost controller, ect.) i dont think youre tryin to adjust youre cams everytimeyou go to ther track. its really up to u. na is more expensive.
Old Apr 13, 2004 | 01:24 PM
89a6T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironchef25 &raquo;</TD></TR><TR><TD CLASS="quote">can i slap a turbo on a stock internals b16? motor has about 45000 miles.
maybe boos like only 5 psi to 7</TD></TR></TABLE>
this kid on my block did it
powerrevracing.com is his web site. he was sparying a 50 shot for about a year on the same motor b4 he boosted it. he ran a 14 flat in 1/4
DRAG 3 kit=$4000(rip off if you ask me)
5psi
fmu(worst fuel mangement money can buy )
untuned(no real dyno time anyway)
98 hb gutted from the backseat back
in your crx a $2000 setup should take you into the 13s easy
TUNING IS THE KEY.
Old Apr 13, 2004 | 01:34 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
You know... if you want an autoX track car, generally an N/A build would be the key here.
For the 1/4 mile, go for whatever, but Boost is usually preferred here... it's cheap, easy, and reliable if you do it right.
An N/A 12 sec build would be something like a B20/VTEC, with a Type R head, and bolt-ons. As for 13s, you could build an LS/VTEC, (if you do it right I assume) or you could put a NO2 kit on it, and run 12s.
I'd just get the B18C block, some nice stage 2 cams, valve train, and a port job. There you go, NA 13s, and a KICK *** AutoX motor.
But if you go turbo, just remember that they heat up fast, and they need to be taken care of.
Old Apr 14, 2004 | 05:27 AM
ironchef25's Avatar
Default Re: (VashTheStampede)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VashTheStampede &raquo;</TD></TR><TR><TD CLASS="quote">
But if you go turbo, just remember that they heat up fast, and they need to be taken care of.</TD></TR></TABLE>
with what? heat wrap?
Old Apr 14, 2004 | 06:13 AM
with what? heat wrap?</TD></TR></TABLE>
No, they need to be checked for damage, they need fresh oil more often than N/A, and they're just going to take more time to get to be reliable.
Old Apr 14, 2004 | 06:22 AM
Sampsonite987's Avatar
It all depends on who is driving the car for it to be reliable, if some kid installs his own turbo and doesnt do it right, there goes his motor, but on the same note, it takes work to build an n/a beast, again if he doesnt do it right, boom! It all depends on if you know what you are doing, and you respect your car.
Eplusz
Mar 20, 2010 11:34 AM
uberhaulin
Mar 7, 2007 06:19 PM
95accordh22a
Nov 23, 2005 07:30 PM
APEXcoupe
Jul 21, 2005 08:08 AM
tan2
Sep 3, 2003 06:40 PM
